Page 1 of 4 1 2 3 4
HELP, Dash Fire, updated Pics #649226 09/22/05 09:44 PM
LRJ4x4 Offline OP
I'm driving along today and out of nowhere white smoke starts to fill the cabin. It's coming from the dash around the speedo and Tach. I pull over in a parking spot and start looking for the Fire Ext in the back and the smoke stops. I quicky disconnect the batttery. <img src="/forums/images/graemlins/angry.gif" alt="" />
What the hell is in there that could cause a fire? Everything was still working when I turned it off. The top was very hot so I sat there a while and waited for it to cool down. I didn't want to leave the truck and come back to a burned out hulk. No blown fuses? Could the speedo cable cause this?
Re: HELP, Dash Fire [Re: LRJ4x4] #649227 09/22/05 10:00 PM
Gauge cluster electronics maybe? I doubt the speedo cable or you'd hear it.
Re: HELP, Dash Fire [Re: LRJ4x4] #649228 09/22/05 10:11 PM
CapnCrunch Offline
I have no idea, but please be sure to post your findings on this one. What could happen to one '88 could happen to another. <img src="/forums/images/graemlins/scared.gif" alt="" />
Good luck Les...I hope it's quick, easy, and inexpensive to find/fix. <img src="/forums/images/graemlins/patriot.gif" alt="" />
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: HELP, Dash Fire [Re: LRJ4x4] #649229 09/22/05 10:21 PM
Kevin C Offline
I have a spare 87 wiring harness for a manual tranny and a few other parts from the smoking area.
Re: HELP, Dash Fire [Re: Kevin C] #649230 09/22/05 10:34 PM
LRJ4x4 Offline OP
Thanks, I'll try to get it pulled tonight. I'm curious as to the damage. I'll take the digital cam so all can see <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: HELP, Dash Fire [Re: LRJ4x4] #649231 09/22/05 10:43 PM
W
wyleone Offline
Blower resistor, blower motor, blower switch, all high currant draws to create a fire.
Re: HELP, Dash Fire [Re: wyleone] #649232 09/22/05 11:02 PM
8
89IsMine Offline
Check the gate lock switch. Mine self-destructed recently through my own stupidity, and there was certainly white smoke coming from the dash... <img src="/forums/images/graemlins/frown.gif" alt="" />
Eric
Re: HELP, Dash Fire [Re: 89IsMine] #649233 09/23/05 12:09 AM
FranklinP Offline
Got a critter munching on the wires? Rats love insullation on wires.
1989 Dodge Raider V-6, 33" Swampers.
Raider pics
Re: HELP, Dash Fire [Re: LRJ4x4] #649234 09/23/05 12:42 AM
philCA Offline
In the absence of physical evidence, an area of possibility is the fuel gauge since it incorperates a constant voltage relay which reduces battery voltage to 7 volts for this guage and the water temperature guage. If this is a mechanical relay and the points fuse together, the coil might short and burn. If the relay is a solid state type and shorts, it typically smokes. Resistane values for the guage are given on page 8-124 of the 87 FSM. Hope the damage is minimal.
1987 Raider 2.6L 5 spd w/ LSD off road package 130K miles
1987 Conquest 2.6L 5 spd w/ intercooler 56K miles
2000 4Runner locking RA 34k miles
Re: HELP, Dash Fire [Re: philCA] #649235 09/23/05 01:04 AM
Kevin C Offline
Good point.. Another place to look is the switch for the emergancy flashers, less likely to smoke but still trouble prone.
Kevin
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6448 MB (Peak: 0.7679 MB) Data Comp: Off Server Time: 2026-05-27 21:19:57 UTC
