rear brake line
#649458
09/23/05 05:28 PM
Is there any rule for how much lift can be done before a extended rear brake line is required? Thanks
02TRDexcab,gray wire mod,magnaflow,PIAA,dog
Re: rear brake line
[Re: taco99]
#649459
09/23/05 07:06 PM
At 3" of lift on my truck the back brake line was as tight as a guitar string...You could probably get away with 1" but I personally wouldnt go any higher because if you offroad when your axle droops thats one inch less you have of brake line...I dunno if that makes any sense, but it made sense in my head...Why dont you just buy the longer lines so you can lift it as high as you want?
1999 Black TRD Prerunner X-Cab V6 3 Revtek Lift 32x11.50 BFG AT 8"x2.5" Sway Away remote resi. coilovers and Total Chaos upper arms sitting in the garage begging to be installed
Re: rear brake line
[Re: taco99]
#649460
09/24/05 11:01 PM
Toyota Moderator
I've seen a number of (Tacoma) rear lifts where the shocks were limiting the droop. So even if you think the length of the brake hose is o.k., it might not be if a rear shock breaks while wheeling. As near as I could tell, everyone of our sponsors at the top of the page offers an extended length hose for about $29. Pretty cheap insurance compared to a PITA trail repair <img src="/forums/images/graemlins/nana.gif" alt="" /> <img src="/forums/images/graemlins/pfft.gif" alt="" />
Wheeling a Stepside Tacoma on 37s Exploring in a T4R Ltd V8
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5929 MB (Peak: 0.6460 MB) Data Comp: Off Server Time: 2026-06-10 06:10:03 UTCValid HTML 5 and Valid CSS
