Is it safe to run E85 fuel in the 3.5 V6? #649522 09/23/05 11:22 PM
TeaQue Offline OP
I noticed the other day that a gas station 10 minutes from my apt sells E85 and its only $1.90!
Sure beats gas around here... $2.75 for 87 octane <img src="/forums/images/graemlins/shiner.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: TeaQue] #649523 09/24/05 02:40 AM
52degrees Offline
I know the 3.0L will burn it without major issues. I don't know about the 3.5L.
Clay
KG6VNX
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: 52degrees] #649524 09/24/05 03:07 AM
TeaQue Offline OP
Clay
Do you have any idea as to where I could find out?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: TeaQue] #649525 09/24/05 03:21 AM
52degrees Offline
Neither engine is listed as being E85 compatable. I've never owned a 3.5L so I don't know where to go to find out what it'll run on.
I can say from my own experience that a 3.0L will run on just about anything that is combustable as long as there is more gasoline in it than whatever else you run.
I did have minor issues when I ran 65% alcohol in it. It would hiccup and turn on the check engine lamp.
I've run very high percentages of diesel fuel. Something like 50% or maybe a little more. Ran great on that.
Wish I had a definate answer for you with your engine, ubt I don't.
Clay
KG6VNX
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: 52degrees] #649526 09/24/05 04:43 AM
W
wyleone Offline
Like Clay said they are not listed as compatable. You know where the label in the gas door says "Unleaded Fuel only"?
Vehicles that are E85 compatable have "Unleaded or ethanol fuels only" The E85 is cheaper but my wifes car FFV Taurus states that it gets less fuel milage on it, approx 6 mpg less. Take into account the price difference, you are not gaining much. Besides if the motor is not prepared for Ethanol, I would think it would suffer detonation (preignition, bad) The Misu knock system may not be able to retard the ign timing enough to prevent possible valve/ piston damage, but you never know.
Maybe some of the chemists around here can confirm or deny my assessment. <img src="/forums/images/graemlins/notooth.gif" alt="" />
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: wyleone] #649527 09/24/05 06:48 AM
TeaQue Offline OP
Well, I don't think I'll try it then....
I just get tired of getting 12mpg <img src="/forums/images/graemlins/drunk.gif" alt="" />
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: TeaQue] #649528 09/24/05 07:51 AM
sparkem Offline
All you get is 12MPG??
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: sparkem] #649529 09/24/05 09:21 AM
TeaQue Offline OP
In the city yes.
Isn't that normal for a 3.5?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: TeaQue] #649530 09/24/05 02:34 PM
Fancy87Raider Offline
where can i find this E85 i will try to run it in everything <img src="/forums/images/graemlins/shiner.gif" alt="" /> whats the worst that can happen. i have a whole family of gas guzzlers <img src="/forums/images/graemlins/barf.gif" alt="" />
87 Raider-31x10.5 Trexus M/T,5" Shackels,T-Bars jacked up,home made CHOP-TOP
Re: Is it safe to run E85 fuel in the 3.5 V6? [Re: Fancy87Raider] #649531 09/24/05 04:33 PM
lordtrunks Offline
premium is what he 3.5 wants says it right on the fuel door.
89 2 dr turbo diesel
89/88 "Backwoods sas"
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6413 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-11-16 01:17:13 UTC
