Hydraulic Clutch conversion questions. #649828 09/25/05 04:28 AM
winstonwrenchhead Offline OP
The franken jeep is coming together nicely just a quick question about putting the hydraulic clutch system together. I am using a 258 with a NP435 tranny, and I have the complete MS and SS setup from an 82 4 cylinder. The pushrod appears to be too short. For those who know or those who have done it, what vehicle do I have to rob to get the right size clutch rod?
Thanks ya'll
<img src="/forums/images/graemlins/patriot.gif" alt="" />
1982/1992 CYJ "FrankenJeep" SOA with Waggy Springs 1" body, 4.0 head, borla headers & cat back, mopar MPI, Jacobs ignition, York air, Custom 3" intake w/k&n, K5 heater, Flexlight fan, 33" Coopers, DANA 44's, lockright up front, NP 435...In progress.
Re: Hydraulic Clutch conversion questions. [Re: winstonwrenchhead] #649829 09/25/05 05:14 PM
BigJim Offline
Winston measure zackly what you need and get out the old pushrod strecher... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Hydraulic Clutch conversion questions. [Re: BigJim] #649830 09/26/05 01:52 AM
riiiiiiiiight....
Re: Hydraulic Clutch conversion questions. [Re: winstonwrenchhead] #649831 09/26/05 06:40 AM
Some good info on how to make the necessary pedal modifications - http://www.monsterslayer.com/jeep/HydClutch/HydroClutch.htm
All of this is for CJ pedals. I can't remember if the frankenjeep is CJ or YJ. The pedals may be the same on either anyhow.
Re: Hydraulic Clutch conversion questions. #649832 09/26/05 03:27 PM
Thanks for the link. I've read it before but it didn't help. I'll scrounge around the junkyard for a longer pushrod.
Re: Hydraulic Clutch conversion questions. [Re: winstonwrenchhead] #649833 09/26/05 04:32 PM
BigJim Offline
Winston Measure zackly what you need and saw yours in half and ADD what you need.. It should not be too hard to EXTEND the length of a simple rod.
Re: Hydraulic Clutch conversion questions. [Re: BigJim] #649834 09/27/05 01:49 AM
Thats what i do jimbo, then i get it red hot an drop it in
cold water for a quick quench, Seems to stiffen it up just
rite.
Re: Hydraulic Clutch conversion questions. #649835 09/28/05 12:39 AM
Gosh I should have asked sooner <img src="/forums/images/graemlins/kewl.gif" alt="" />
I'll get right on that...but really nobody had to get a longer pushrod?
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6151 MB (Peak: 0.6969 MB) Data Comp: Off Server Time: 2026-06-17 04:16:12 UTC
