overbored 22r what kind of HP should I expect? #650938 09/29/05 04:02 AM
SHAD Offline OP
A friend of mine is giving me a tired 22re out of his 1989 pickup. It has somewhat of a rod knock so I may have to source a crank if I can't have this one cleaned up.
Is .040 the max I can bore this motor out to?
Is it worth it to punch it over this much?
I want a torquer 22r motor and was thinking of running o/s valves in it too.
What kind of HP gains would I get out of a overbored motor?
Anything else I should add to this when I build it besides different valves and a rv cam?
Any tips or pointers on this subject would be appreciated.
Thanks
86 Toyota 4 runner
35x12.5 BFG MT's, 4.56's XRC8 winch
My cardomain page
Re: overbored 22r what kind of HP should I expect? [Re: SHAD] #650939 09/29/05 04:11 AM
4Crawler Offline
Mine is 0.020 oversize and that bumps you from 2366cc to 2392 cc, a whopping 1% increase. I guess 0.040" over would net you a 2% increase in displacement over stock.
Re: overbored 22r what kind of HP should I expect? [Re: 4Crawler] #650940 09/29/05 07:37 AM
kyle-22r Offline
i know you can got at least 60 over on a 22R, but i don't think it's worth it unless you're having a really hard time finding a good block.
as a rule of thumb on these, punch them out only enough to clean up the cylinder walls. my 20/22 is 40 over because of a deep mystery nick in the #1 cylinder wall when i tore it open.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: overbored 22r what kind of HP should I expect? [Re: kyle-22r] #650941 09/29/05 12:42 PM
SHAD Offline OP
Only reason I am concidering even building 22re is it's free to me. I figured some machine shop work might give me some more HP to the motor.
I still want to do a 5mge in my truck but worried about the 5mge motor being alot heavier than the 22re.
Right now my weight distribution is centered pretty well running a g54 transmission in it.
If I had a supra motor I imagine it would be nose heavy because of the addional weight.
That's another reason why I am concidering building a 22re and not putting a 5mge into it.
86 Toyota 4 runner
My cardomain page
Re: overbored 22r what kind of HP should I expect? [Re: SHAD] #650942 09/29/05 09:24 PM
ToyotaT Offline
I did 30 over on mine. Didn't notice a whole lot of difference. EB's RV head and cam made a difference though <img src="/forums/images/graemlins/cheers.gif" alt="" />
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: overbored 22r what kind of HP should I expect? [Re: SHAD] #650943 09/29/05 09:27 PM
84toyota Offline
You should read through this post about the 7mge swap... I believe I remember reading that once the swap was done, there was only an additional 30 pounds of weight! I might have read that on Marlin's Forum where the swap has been documented as well...
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: overbored 22r what kind of HP should I expect? [Re: 84toyota] #650944 09/29/05 11:18 PM
OOP'S Offline
Machine work alone will not do much for you. Now if you overbore, blueprint, higher compression pistons, strocker, cam, OS valves, port and polish,ignition, header, and carb you will see an increase and you will also lose reliability and longivity of engine life and it is still a 22r!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6202 MB (Peak: 0.7113 MB) Data Comp: Off Server Time: 2026-10-24 13:09:07 UTC
