Thermostat #650963 09/29/05 06:44 AM
4
4x4yotaman Offline OP
I plan on replacing my thermostat tommorow and I was wondering if u guys had any recomendations on what brand and tempurature thermostat I should get.
1985 4runner
Re: Thermostat [Re: 4x4yotaman] #650964 09/29/05 06:53 AM
4Crawler Offline
I use this one: http://www.4crawler.com/4x4/CheapTricks/index.shtml#Thermostat
I got a spare one a few years ago, and not only did my dealer have it in stock, but they also knew what it was for when I asked for the part number.
Re: Thermostat [Re: 4Crawler] #650965 09/29/05 07:47 AM
87Toy4x4 Offline
my toyota dealer says the two stage is no longer available. i even gave them the part number.
Re: Thermostat [Re: 87Toy4x4] #650966 09/30/05 09:46 PM
Stan_Marshall Offline
just get the regular one and drill a little hole in the flange...accomplishes the same thing.
1994 4x4 22RE W56 truck
Re: Thermostat [Re: Stan_Marshall] #650967 10/01/05 12:39 AM
randito Offline
I just went to a toyota dealer for a therm about 2 weeks ago. They had the 2 stage unit in stock, but it cost about $30, where as the single valve was $16. If you get the single stage and drill a hole, just make sure that you only go 1/16" as 4crawler's write up recommends. I made the mistake of drilling a hole too large on a perfectly good t-stat and my engine ran too cool and took forever to warm up.
1985 runner, completely stock(still)
Re: Thermostat [Re: randito] #650968 10/02/05 06:04 AM
J94_4runner Offline
I'm running a NAPA 180 degree with a hole drilled in the flange. Works great.
www.celicasupra.com
Re: Thermostat [Re: 4x4yotaman] #650969 10/02/05 06:51 AM
kewlynx Offline
Wow, you're way up there. I used to be stationed near Oscoda at Wurtsmith back in the day. Eastern winters suk!! Way too much humidity.
I run a Yota or NAPA 195, yep 1/16" hole for the temp overshoot. Toss an extry behind the seat.
**ubi apis- ibi salus**
Re: Thermostat [Re: kewlynx] #650970 10/02/05 10:53 AM
kyle-22r Offline
i drilled an 1/8" hole in my yellow truck's 195* thermostat, the gauge starts to move by the time i'm at the end of my street...
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6225 MB (Peak: 0.7205 MB) Data Comp: Off Server Time: 2026-06-07 05:50:42 UTC
