Hand Held Tachometer hookup #651638 10/01/05 04:44 AM
Don_W Offline OP
Master,
New Actron CP7677 watchamacallit. Instructions, Hayne's, Chilton's, all tell me to hook to negative coil wire... How do I do this without cutting wire. I see no obvious way to do this at the connector..?
Don
1989 Trooper II 2.6L
222,222
Re: Hand Held Tachometer hookup [Re: Don_W] #651639 10/01/05 02:24 PM
Troopersphere Offline
You should be able to use a safety pin to "backprobe" the connector. Should be the BLUE wire in the connector, and it's the one on the TOP.
HOWEVER: On the left fender skirt, there are two connectors coming from the engine, on a bracket, just behind the battery. If you look there, you should find a BLUE WIRE with a single "bullet" type push on connector. This is the TACH signal test connector. Put your meter probe in that connector and you should be in business.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Hand Held Tachometer hookup [Re: Don_W] #651640 10/04/05 05:49 AM
I know old thread.
Im installing a sunpro tach in my 89 amigo and cant figure out how to hook it to the coil.
There are 2 wires in aharness going to the coil and I know 1 of them is for me .
Do I hoklk into the blue wire for my tach?
Re: Hand Held Tachometer hookup #651641 10/04/05 11:01 PM
not _that_ old, but from what I can tell from the other threads, you may already have your answer ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Hand Held Tachometer hookup [Re: Troopersphere] #651642 10/05/05 05:10 AM
yup, got it hooked up today.
Nice to know where the little 4 banger is revin.
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.013s) Memory: 0.6023 MB (Peak: 0.6668 MB) Data Comp: Off Server Time: 2026-11-19 23:55:23 UTC
