Can't get to A/T oil pan bolts. Help! #651773 10/01/05 08:37 PM
96TrooperSE Offline OP
Okay I think I've got the 4l30E auto transmission. Its a '96 Trooper SE. I'm in the middle of changing the filter and pan gaskets, but I can't get the the main pan bolts in the back. The crossmember that supports the trans. is in the way. Do I have to support the trans and remove the crossmember? Please let me know ASAP.
/1996 Trooper SE\
OME 912's w/2.5" spacers, Superwinch hubs, 265/75R16 Yokohama Geolanders (street), 34x10.50x15 Super Swamper LTB's, Indy4x HD Tie Rods, Indy4x Rock Sliders
Re: Can't get to A/T oil pan bolts. Help! [Re: 96TrooperSE] #651774 10/01/05 10:40 PM
Yes, you do have to remove the crossmember after you've *securely* supported the tranny.
I recently did this job on my Trooper (both of the pans) and it was the single worst automotive repair/maintenance experience I've ever had. <img src="/forums/images/graemlins/angry.gif" alt="" />
I'm seriously considering swapping to a manual tranny.
Re: Can't get to A/T oil pan bolts. Help! #651775 10/01/05 11:38 PM
Yeah I know what you meen. I supported it by the T/C and it is holding up thus far. I got both pans off (thanks to some help from my dad). Now i'm taking a break and cleaning all of the old gasket off the pans. I noticed some gasket sealer on the main pan. Should I put some of this on with the new gasket? I want to do it right so I don't have to do it again.
/1996 Trooper SE\
Re: Can't get to A/T oil pan bolts. Help! [Re: 96TrooperSE] #651776 10/01/05 11:58 PM
JLEMOND Offline
PUT JUST ENOUGH SEALER ON THE PAN TO HOLD IT IN PLACE UNTILL YOU GE TTHE PAN BOLTED UP, YOU DON,T WANT ANY OF THE SEALER TO GET INTO THE TRANS OIL, AND DON,T OVERTIGHTEN THE BOLTS OR YOU WILL CRUSH THE GASKET AND IT CAN LEAK, ABOUT 7 FT LBS OR 85B INCH POUNDS IF YOU HAVE AN INCH LB WRENCH, JERRY
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.5961 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-07-13 15:48:49 UTC
