Quick pinion preload question
#652274
10/03/05 04:46 PM
Quick question. When setting the pinion preload, do you measure the torque needed to get it to start rotating, or the torque while rotating?
This is using a solid spacer with used bearings. It takes about 25 in-lb to get it to begin rotating, and about 6 in-lb to maintain rotation. Bearings are oiled.
Thanks!
Re: Quick pinion preload question
[Re: carter]
#652275
10/03/05 11:31 PM
6 in/lb is the correct number. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: ZUK]
#652276
10/04/05 12:35 AM
So it is ok for it to take a lot more torque to begin rotating? It didn't feel like that when I disassembled it. I didn't take any torque readings on disassembly.
[Re: carter]
#652277
10/04/05 04:03 AM
ya...that can happen. use a thick gear oil....like a teaspoon on both bearings. Helps to smooth it out.
[Re: ZUK]
#652278
10/04/05 10:16 AM
Cool, thanks! <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: carter]
#652279
10/05/05 11:03 AM
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6091 MB (Peak: 0.6786 MB) Data Comp: Off Server Time: 2026-06-07 04:58:38 UTCValid HTML 5 and Valid CSS
