4cyl to v6 swap #652997 10/05/05 02:37 AM
FlaRaider Offline OP
Any body done this? Iv'e got access to a good v6 engine,trans, & transfer case and a less than healthy 4 cyl in my 87raider. Any tips? What about the fuel pump? I've read the tanks won't swap, what about the hanger sender assembly?
Thanks for the help.
Dave
87 Raider - adopted by a new family
89 Raider - sole survivor
88 Montero - adopted by a new family
89 Montero - organ donor - R I P
90 Montero lwb - organ donor - R I P
Re: 4cyl to v6 swap [Re: FlaRaider] #652998 10/05/05 02:52 AM
don Offline
Different electronics, wiring harness, fuel system, air intake, front brakes, motor mounts, etc...
Easier to get a running V6 rig than convert a 4 cyl rig
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: 4cyl to v6 swap [Re: FlaRaider] #652999 10/05/05 03:56 AM
I know they don't swap from a LWB to a SWB, but are you sure that you couldn't swap one from a SWB 3.0L into the Raider?
Re: 4cyl to v6 swap #653000 10/05/05 03:58 AM
87Montero Offline
The V6 Trucks have a larger tank, and are coil sprung.. different frames and tanks do not interchange <img src="/forums/images/graemlins/frown.gif" alt="" /> I already looked into it.
Re: 4cyl to v6 swap [Re: 87Montero] #653001 10/05/05 04:06 AM
The V6 Trucks have a larger tank, and are coil sprung.. different frames and tanks do not interchange I already looked into it.
Darnit! That throws a monkey wrench into the equation on my V6 swap. Oh well, I'll have to figure out a way to frankenbuild something up in the tank since I need high pressure for SFI.
Re: 4cyl to v6 swap [Re: FlaRaider] #653002 10/05/05 04:09 AM
W
wyleone Offline
I guess it's do-able, but other than the motor mounts bolting right up, is no different than swaping to a 4.0L Ford, a 4.3L Chevy, or 3.9L Dodge. All electrics fuel system, trans, tranfer case, and driveshafts have to be created, or swapped from a running vehicle.
Re: 4cyl to v6 swap [Re: wyleone] #653003 10/05/05 04:31 AM
Kevin C Offline
3.0 into a SWB:
Drive shafts dont need to be made and there is a factory EFI harness availible.
The down side is it may be harder to find a good 3.0 and a rebuild is typicly more expensive.
A good 3.0 in a SWB is a nice package... So is a 4.3 or a turbo 2.6 or a.......
Kevin
Re: 4cyl to v6 swap [Re: Kevin C] #653004 10/05/05 04:45 AM
or a.......
GM 3100 SFI (at least I hope so. Most of the parts are gathered)
Re: 4cyl to v6 swap [Re: FlaRaider] #653005 10/05/05 05:15 AM
CapnCrunch Offline
Just use an aftermarket in-line electric fuel pump. I still have my mechanical pump, but I also have an in-line electric pump mounted back near the tank. Helps prevent vapor-lock on my rig at high altitude.
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: 4cyl to v6 swap [Re: CapnCrunch] #653006 10/05/05 06:28 AM
Kevin C Offline
For fuel injection the Starion pump is a decent choice. Its an external pump with good volume and pressure (55 psi is no problem).
I just finished putting one in.
Kevin
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6339 MB (Peak: 0.7565 MB) Data Comp: Off Server Time: 2026-11-16 08:46:31 UTC
