Page 1 of 3 1 2 3
Crank shaft Pulley tools #654117 10/07/05 08:10 PM
F
FEA Offline OP
While I'm about to try and pull this for the timing belt change, can anyone tell me if I need a special tool to get the pulley off as suggested in the manual, or will something more generic work? Thanks.
Francis E. Abate
'95 Trooper
'98 MB ML320
'70 MB 300SEL 6.3
Re: Crank shaft Pulley tools [Re: FEA] #654118 10/07/05 09:44 PM
mtboulder Offline
Sometimes an air impact wrench will remove the pulley bolt. Other times you need a way to keep the pulley still while you break loose the bolt. I've wrapped the pulley with rags and then used a chain wrench to hold it still.
Another approach is to put a breaker bar on the bolt and lean it on the frame and then just tap the starter using the ignition key and it will break the bolt loose.
Re: Crank shaft Pulley tools [Re: mtboulder] #654119 10/07/05 10:08 PM
barak Offline
The easiest way to get it off is to have the proper tool.Makes it way easier and they aren't that expensive.I think I paid like 20 bucks for mine.
Re: Crank shaft Pulley tools [Re: FEA] #654120 10/07/05 10:24 PM
It is a simple puller - as mentioned, purchased inexpensively or can usually be "rented" for free from AutoZone/Checker's/etc...
Re: Crank shaft Pulley tools #654121 10/08/05 01:14 AM
F
FEA Offline OP
THanks for all the quick responses - it's really the nut that presents the problem as you know - Interesting the dealer tech said they use the starter trick and a local friend of mine has used a strap wrench with success to remove the nut.
I'll post my (positive!) results.
Francis E. Abate
'95 Trooper
'98 MB ML320
'70 MB 300SEL 6.3
Re: Crank shaft Pulley tools [Re: FEA] #654122 10/08/05 01:28 AM
F
FEA Offline OP
Oh yeah - is that a 22MM or 15/16 nut? I don't have a 22, but 21 won't fit and 15/16 will - dont want to strip it.
Francis E. Abate
'95 Trooper
'98 MB ML320
'70 MB 300SEL 6.3
Re: Crank shaft Pulley tools [Re: FEA] #654123 10/08/05 01:32 AM
Jim_Paget Offline
If it is on your Isuzu Trooper, it is metric. You can do the math or test the fit to decide whether or not a factional size socket is "close enough" for you.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Crank shaft Pulley tools [Re: FEA] #654124 10/08/05 01:33 AM
Troopersphere Offline
It's a 22, but I've always used 15/16 with no trouble so far. I've had good luck just putting the truck in 5th, locking the hand brake and having at it with a 1/2" drive breaker bar. Don't try to "*****" it off there, grab a holt of that thing and PULL!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
HA HA ... there must be naughty word filters... those stars aren't what I typed... ok then, don't try to "BABY" the bolt loose. Give it a good manly PULL!!!!
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Crank shaft Pulley tools [Re: Troopersphere] #654125 10/08/05 01:44 AM
F
FEA Offline OP
Yes it's the Trooper - now I read before somewhere about putting it in 5th gear (I do have a manual tranny), but what does this do - does it hold the pulley?
Francis E. Abate
'95 Trooper
'98 MB ML320
'70 MB 300SEL 6.3
Re: Crank shaft Pulley tools [Re: FEA] #654126 10/08/05 02:19 AM
Well, it holds the engine from turning over, and it should hold it enough for you to break the bolt loose. Works on mine, but others have not had as much success. Try this first, it's the easiest way, resort to more drastic measures only if needed.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6382 MB (Peak: 0.7622 MB) Data Comp: Off Server Time: 2026-06-07 11:37:41 UTC
