low idle #654262 10/08/05 04:45 AM
salvo Offline OP
searched and could not find the post i had seen about this... When i came home from work tonight i noticed that when stopped it was ideling 400 - 600 rpm below normal almost stalling .. the engine runs fine at highway speeds and through town... just not when im sitting at the stop light.
Re: low idle [Re: salvo] #654263 10/08/05 04:43 PM
Kaptain Offline
Turn the Idle Adjustment screw and set the idle at 850 (With engine warmed up of course).
93' Toy xCab
bobbed > 22rEB > w56 > stock duals > SAS > 4.88's > 37's
Re: low idle [Re: salvo] #654264 10/08/05 08:18 PM
Scotty_Gotti Offline
if that doesn't solve the problem look for check engine codes. My truck was doing this a week ago and it turned out my Mass Airflow Sensor was dead
Re: low idle [Re: salvo] #654265 10/08/05 11:49 PM
Esquire812 Offline
If it stays idling long enough, open the hood and give the EGR valve a good tap and see if this cures the problem. If not, disconnect the EGR from the intake plenum, install a temp block off plate and then see how it idles. If idle returns to normal you need to either clean or replace the EGR valve.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: low idle [Re: Esquire812] #654266 10/09/05 08:43 AM
salvo Offline OP
hmmm i have th eself healing truck... Went to work today and by the time i got to work everything was fine again... Going to pull the intake off this week and give it a good cleaning..
Re: low idle [Re: salvo] #654267 10/09/05 08:50 AM
kewlynx Offline
Salvo, FWIW, I'm cleaning up some parts right now; the EGR plate on the back of the head was clogged; easily 50%. <img src="/forums/images/graemlins/scared.gif" alt="" />
What I'm saying here is that it might not just be the valve; could be both.
You'd want to round up a gasket for it to go back together; I don't know if a fabbed one out of gasket material will be suitable or not. Anyone know? Mine are backordered. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
**ubi apis- ibi salus**
Re: low idle [Re: salvo] #654268 10/09/05 04:54 PM
4Crawler Offline
A sticking EGR valve will act like that. Fine one day, acts up the next, gradually will get worse. As Darin mentions, tapping on the EGR when the idle is rough is a good test, that can loosen the EGR valve to let it close. A gun cleaning kit is a good tool for cleaning the EGR if needed. Small wire brushes and gun cleaning solvent work well to remove the buildup inside.
Re: low idle [Re: kewlynx] #654269 10/09/05 05:43 PM
Buster Offline
My local dealer and auto part stores didn't have that gasket in stock either so I used high temp RTV. Worked great and no leaks. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: low idle [Re: kewlynx] #654270 10/09/05 07:58 PM
Esquire812 Offline
Dont short cut this one, the holes are precise and the material has to handle extreme heat cycles...not to mention if you are lucky enough to have the later cast iron exchanger instead of the older aluminum. If you need a couple of them gaskets Margi, let me know....Ive got a couple around from various projects when the plate wasnt removed. No back order!! And best of all....USPS can handle these. <img src="/forums/images/graemlins/pfft.gif" alt="" />
85' Sillyca 22R-Esq
Re: low idle [Re: Esquire812] #654271 10/10/05 07:27 AM
salvo Offline OP
Well thanks for all the info... guess i will go to the pars store and see if i can order the gaskets i need... Ive been wanting to take the intake off anyway to clean and paint so this now gives me a good reason to do it..
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6356 MB (Peak: 0.7439 MB) Data Comp: Off Server Time: 2026-10-24 13:10:49 UTC
