Water Pump Question - 95 Trooper #654332 10/08/05 05:51 PM
F
FEA Offline OP
NOw the timing belt cover is off (no one warned how hard that left side cover would be to remove, chipped off some pieces) - if the water pump is weeping antifreeze from the top hole, is that normal? Or should I replace - I wasn't planning to because I am going to sell the vehicle right after this 120K service, but will do if it's aproblem for the next few weeks before selling.
Thanks.
Francis E. Abate
'95 Trooper
'98 MB ML320
'70 MB 300SEL 6.3
Re: Water Pump Question - 95 Trooper [Re: FEA] #654333 10/09/05 02:31 PM
Madcat Offline
Coolant weeping through the holes means the internal seals of the pump are worn out. It can cause overheating if it gets worse <img src="/forums/images/graemlins/shame.gif" alt="" />. Plus if anyone goes to buy it and sees coolant leaking they'll either run <img src="/forums/images/graemlins/scared.gif" alt="" /> or try to knock you down in the price <img src="/forums/images/graemlins/evil.gif" alt="" />. Change it <img src="/forums/images/graemlins/cheers.gif" alt="" />.
Madcat <img src="/forums/images/graemlins/kewl.gif" alt="" />
1979 Pontiac Trans-Am - looking 4 a pontiac 455cid
1988 Trooper II - AMC head, .030 overbore, Calmini cam. Toga HV oil pump, Aisins, soon 2 b turbo
1989 Impulse Turbo - Fidanza flywheel, 270cc injectors, turbo-back exhaust, KYBs F/R
Re: Water Pump Question - 95 Trooper [Re: Madcat] #654334 10/11/05 12:49 AM
F
FEA Offline OP
Done - interestingly the hole I thought was for weeping, was a bolt hole with a missing bolt - two other were loose. This was the factory pump - anyone notice this before?
Francis E. Abate
'95 Trooper
'98 MB ML320
'70 MB 300SEL 6.3
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.5939 MB (Peak: 0.6478 MB) Data Comp: Off Server Time: 2026-11-18 03:44:23 UTC
