oil pan gasket #655193 10/11/05 06:51 AM
A
Andy_92563 Offline OP
Any suggestions on how to change the oil pan gasket for a 99 tacoma? its leaking a bit. Any helpful suggestions is appreciated.
Andy
-Andy
1999 Tacoma Black Limited V6, 4x4,104K,LEER shell cover, deck plate air box amsoil air/oil filters w/ amsoil fluids, bilsteins shocks front & rear
3" toytec coils & AAL, 4 new TOYO tires (31x10.5x15). selling truck to the right price!!
Re: oil pan gasket [Re: Andy_92563] #655194 10/15/05 01:37 PM
First just see if the bolts are loose. Fortunately I haven't had to do this myself so I'm not sure the proceedure, but the factory manual is pretty good.
Re: oil pan gasket [Re: Andy_92563] #655195 10/18/05 04:24 AM
bard Offline
The best advice for actually replacing it would be clean it, clean it, clean it and then clean it again. Wipe all the surfaces with paint thinner to remove all traces of oil then apply a thin layer of RTV to both sides of the gasket. A thick bead means stuck forever, a thin bead only means a good seal.
Re: oil pan gasket [Re: bard] #655196 10/18/05 04:14 PM
A
Thanks for your input guys.
-Andy
Re: oil pan gasket [Re: Andy_92563] #655197 10/19/05 03:53 AM
J94_4runner Offline
Our '00 3.4's oil pan gasket started leaking pretty good toward the rear of the pan. that was the 1 thing the crusty toyota warranty covered, i was suprised they did. my '94's 3.0 oil pan gasket... 135K miles... dry:) theres a difference between newer yotas and older yotas.
www.celicasupra.com
Re: oil pan gasket [Re: J94_4runner] #655198 10/19/05 03:52 PM
Red_Chili Offline
Toyota Section Staffer
I used FIPG, no gasket. No problems either!
-Bill
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6079 MB (Peak: 0.6771 MB) Data Comp: Off Server Time: 2026-11-18 03:44:15 UTC
