Window Motor Removal
#655332
10/11/05 07:43 PM
-tried searching for this but couldn't find what I'm lookin' for...
My 91 Trooper's rear driver side power window has stopped working. I pulled the panel off, found the 2 blue wires that go the motor & verified that I get + or - 12vdc when I use a window switch, so I figure the problem has to be with the motor.
I read in some posts that windows sometimes bind..but this is stuck (thankfully) in the full-up position & won't move.
Anyhow...has anybody removed/replaced one of these motors? I'm not sure if I need to get inside the door, or if it all can be done through the access hole. My svc. manual says nothing about them (of course).
............................................... '90 Trooper LS 2.8, 5spd, 3" body lift, 33x12.5, dent
Re: Window Motor Removal
[Re: MeatWagon]
#655333
10/11/05 11:49 PM
I have replaced them in the front doors on a '91 but not the back, but the procedure is pretty much the same. You need to remove the door panel and then everything can be removed through the access holes.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5846 MB (Peak: 0.6330 MB) Data Comp: Off Server Time: 2026-06-17 05:17:12 UTCValid HTML 5 and Valid CSS
