header ques. #655787 10/13/05 02:01 AM
E
EDS2000tacoma Offline OP
I am Thinking about geting a header from LC engineering. the ques. i have is what do i do with the EGR piping. if anyone has put one a nother type of header i would like some feed back.
Eric S.
2000 Tacoma
-6in of lift,33x12.50 truxx's M/T's
Re: header ques. [Re: EDS2000tacoma] #655788 10/14/05 01:03 PM
88toy4x4 Offline
I am guessing that you have the 4cyl. I have the LCE Header on my 2.7 and it rocks! It fits perfect and I had no problems with the install. The header itself has a extra little pipe on the side of one of the main tubes to hook up to the egr piping. The EGR pipe hooks right up, no problems. Also on the install, you just remove your stock manifold and the down pipe to the catalytic convertor and the header bolts right in. You just need to make sure that your truck does not have 2 catalytic convertors. If yours does, then it will take a little more to install a header.
The power gains are not tremendous, but noticeable. I would definitely recommend getting the header. I also would recommend getting a new higher flow muffler to replace the stock muffler. That will help out also. You don't have to replace the whole exhaust system, just replace the muffler and use the stock tube, unless it needs replacing. It is a little expensive but worth it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: header ques. [Re: 88toy4x4] #655789 10/26/05 09:51 PM
Denvertaco Offline
Yep, I have one too. Best thing I did for that truck. I have the cat back too. I had two cats on mine but with a little mod at the muffler shop it works great! <img src="/forums/images/graemlins/kewl.gif" alt="" />
03 Double Cab TRD.. ARB, warn winch, OME coilovers, Alcan leafs, Bilstiens, Sky E-locker guard, etc, bla bla bla
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5934 MB (Peak: 0.6473 MB) Data Comp: Off Server Time: 2026-06-17 11:39:45 UTC
