91 Troop Water Pump #657068 10/17/05 03:59 AM
SleepO Offline OP
I have a coolant smell when I start up, the temp gauge goes to 3/4 of hot before returning to mid-line, if it sets for more than two days a leak appears on the front drivers side of the engine compartment, occasionally there is a whining for a minute after startup. Could this be a water pump?
How big a job is this with a Chilton's manual/shop repair?
Any suggestion welcome.
I bought this rig new and can't part with her.
Love my '91 and '02 Troopers, yet still old and in the way. Stock can be fun too!
Re: 91 Troop Water Pump [Re: SleepO] #657069 10/17/05 05:06 AM
Jim_Paget Offline
Which engine are you talking about, L4 or V6?
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: 91 Troop Water Pump [Re: SleepO] #657070 10/17/05 11:53 PM
Troopersphere Offline
In spite of the engine size, the temp going up and dropping back would be an indication that the thermostat is sticking, and should be replaced.
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: 91 Troop Water Pump [Re: Troopersphere] #657071 10/20/05 04:00 PM
SleepO Offline OP
Its a V6. Is there a seep hole that I can visualize to see if fluid is getting around the bearings?
Re: 91 Troop Water Pump [Re: SleepO] #657072 10/21/05 01:43 AM
Jim_Paget Offline
On the V6, changing the water pump, if that is what the problem is, is not a big deal.
Basically you need to get the fan shroud out of the way, you may need to remove the power steering pump, depending on the number of angles that you elbows can achieve and the same for the A/C compressor.
Once you can get to it, unbolt the water pump. Clean the gasket surface, and reinstall the new pump.
There is a weep hole, but you may need a double jointed eyeball to see it.
Jim Paget
www.rrr4x4.com
Re: 91 Troop Water Pump [Re: Jim_Paget] #657073 10/29/05 06:04 PM
8
88bronzetrooper Offline
I have a 4cylinder but when mine was doing the 3/4 up on the temp guage befoe going to the half way point on the guage. It ended up being my fan clutch. I even changed the thermostate and it helped for a day but then it started again. When i changed my fan clutch it fixed it and now goes the a little more than quarter way and stays there for the whole time.
88 Trooper. 1.5 inch lift. Rancho's, manual hubs, header, muffler, High flow cat, 2.5 all the way back, Aussie Locker, CB and 31 10.50's
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6113 MB (Peak: 0.6811 MB) Data Comp: Off Server Time: 2026-06-07 04:16:48 UTC
