Where to find tall jack stands? #657693 10/19/05 03:20 AM
BuleToy Offline OP
Trouble finding jack stands that can extend to approx. 3.5-4' I want to place them under the frame. I need to work on rear springs and have about 5" of lift. Hoping to make it a little easier and safer to remove the rear axle. Rocker bars and bumpers are no longer on, so hiLift won't work.
Re: Where to find tall jack stands? [Re: BuleToy] #657694 10/19/05 03:32 AM
4Crawler Offline
No need for that tall a stand, Harbor Freight has some around 30" tall. I use some a little shorter than that. I made a base out of criss-crossed 2x4s the sixe of the jack stand base. 2 boards across and 3 vertical:
Raises them up about 3" and is plenty tall. Also helps keep the stands from sinking into my asphalt driveway.
My rear axle will basically drop to the ground (w/ tires off of course) w/ 5.5" Alcan springs and longer than stock shackles.
For taller stands, you could fab up your own or make a taller base for them.
Re: Where to find tall jack stands? [Re: 4Crawler] #657695 10/19/05 03:52 AM
BuleToy Offline OP
Thanks! In fact I have the same stands and same sinking problem. An easy and cheap solution.
Re: Where to find tall jack stands? [Re: BuleToy] #657696 10/19/05 04:59 AM
Robinhood150 Offline
Every once in a while the harbor freight 24" jack stands go on sale for $30 (I think it was $30, maybe $20).
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6034 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-06-07 13:03:33 UTC
