'92 Isuzu Rodeo Rearend Swapping #657739 10/19/05 05:26 AM
I've got a '92 Isuzu Rodeo, 3.1 V-6 5-speed, 10-bolt GM rearend. Rearend died on me today, and I have heard that the Chevy S-10 rearend would work. Can anyone confirm this? I see S-10s everywhere, parts are cheap, and I've already got a line on an '86 or '87 S-10 with a dead 2.8, good rearend. Your assistance is much appreciated.
Re: '92 Isuzu Rodeo Rearend Swapping #657740 10/19/05 01:40 PM
RobG Offline
I would say probably, but why are you messing with another 10-bolt?
why not pick up a Dana44 from a 94-97 Rodeo... its a bolt in swap too, many have gone that route before. There are some significant benefits to having the D44 over the 10-bolt.
-Rob
Robert Gorrell
1995.5 Isuzu Rodeo - SAS'd and SOA'd, sitting on 38x13 TSLs, spooled D60 front, 14bff rear locked by detriot, high steer w/ hydro, dual Isuzu tcases.
Re: '92 Isuzu Rodeo Rearend Swapping [Re: RobG] #657741 10/19/05 04:42 PM
Thanks for the reply. My Isuzu is my daily driver, and as of right now, the only vehicle running in the household. I am currently driving it with the rear driveshaft removed from it, and the front hubs locked. I am just looking for the easiest and quickest solution to get the truck back up to 100% again, and S-10s are plentiful around here.
Re: '92 Isuzu Rodeo Rearend Swapping #657742 10/19/05 04:51 PM
RobG Offline
So what exactly is wrong with it that you can continue to drive in that configuration? Obvisouly, everything this is still spinning regardless of power going to the yoke or not.
One of your challenges with the Chevy 10-bolt swap is locating a Chevy with a matching gear ratio. Isuzu typically used much numerically higher gears than their american counterparts.
-Rob
Re: '92 Isuzu Rodeo Rearend Swapping [Re: RobG] #657743 10/19/05 05:03 PM
Rearend makes a crunching sound now, and with the driveshaft removed, you can turn the pinion yoke almost half a turn. Non-matching gear ratio is not a real concern for me as I usually don't use 4wd with my truck.....just looking to get the truck back up to 100%. If I have 1 more drivetrain related failure with this truck, we are officially screwed, 'cause I don't have another vehicle that is roadworthy or legal yet. I have a Ford Taurus wagon, but I am waiting on the title, and my wife wrecked her '98 Plymouth Breeze 3 weeks ago, and the truck is all I have.
Re: '92 Isuzu Rodeo Rearend Swapping #657744 10/19/05 11:01 PM
9
94redrodeo Offline
Just get a dana 44 it will bolt right in and you will have the right gear ratio and it won't be a 10 bolt you can probably pick one up for about $200.
The S10 10 bolts are 5 lug probably have diffrent spring and shock mounts.
So I think the Dana 44 is a Cheaper and more reliable option.
94 Rodeo 3+3 lift Red)
95.5 Rodeo 1" Body lift Dana 44' front & rear 4.88 gears 35"s 176,000 miles Optima Yellow top InexAir Co2
front winch bumper custom rear bumper, Hella 500's
2004 Silverado duramax
Re: '92 Isuzu Rodeo Rearend Swapping [Re: 94redrodeo] #657745 10/19/05 11:46 PM
Jim_Paget Offline
The other option is an Isuzu 12-bolt. This has been done before. The only real issue is the emergency brake cables and the need to have the driveshaft be the right length (I don't remember whether it needs to be shortened or lengthened).
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: '92 Isuzu Rodeo Rearend Swapping #657746 10/20/05 04:46 AM
hunterdan Offline
Look for a D44 out of a Rodeo, its a direct bolt in replacement if you find one with drum brakes (2wd 4cyl models are the best choice), is significantly stronger and can be swapped out in less 2 hours, I've done it, so if I can do it, you can too. Oh yeah, and the gears matched.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: '92 Isuzu Rodeo Rearend Swapping [Re: Jim_Paget] #657747 10/20/05 11:40 AM
MattGold Offline
I did the 12-Bolt Swap. The advantage for me was that I went from a 4.30 to a 4.56 ratio because I did the front third and the rear end and I got disk brakes in the rear. I wouldn't really call this a drop in swap though. As Jim mentioned, I had to play around with the E-Brake cables. You will also want to find a rear end with matching tone ring. Otherwise your Rear ABS will be disabled. Not that it was really that helpful anyway.
Last but not least I also did the one-peice drive shaft as my carrier bearing went around the same time.
Matt
92' Rodeo with a lot of DOR parts
Re: '92 Isuzu Rodeo Rearend Swapping #657748 10/25/05 09:55 PM
90amigo Offline
3 times I could of bought a D44 rear from a rodeo for $250.
At 2 diff salvage yards.
Ask a yard.
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.006s) Memory: 0.6353 MB (Peak: 0.7545 MB) Data Comp: Off Server Time: 2026-10-30 10:23:13 UTC
