Installing and adjusting new Carb, anything to look out for?
#658006
10/20/05 03:55 AM
Title pretty much says it.
The idle mix screw doesn't have a plug over it on the new one, so I'm going to assume I'll have to do the lean drop method described in the FSM, which I think I understand, but any clarification anyone could offer would be great.
Re: Installing and adjusting new Carb, anything to look out for?
[Re: stock87]
#658007
10/20/05 04:38 AM
If you have a FSM, then you should have no prob. setting up the carb.. I did mine back in the summer after my engine rebuild, and it was very straightforward. Also good to check that the choke,fast idle, etc.. are operating properly.
-Darren
'84 Xtra Cab Sold <img src="/forums/images/graemlins/frown.gif" alt="" /> '96 Tacoma in progress <img src="/forums/images/graemlins/smile.gif" alt="" /> God forgives...rocks don't.
[Re: stock87]
#658008
10/21/05 12:59 AM
OK, can someone explain this Lean Drop Method for setting the idle mixture? That part of the FSM didn't quite translate into english correctly...
Thanks
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.5926 MB (Peak: 0.6458 MB) Data Comp: Off Server Time: 2026-11-18 22:34:33 UTCValid HTML 5 and Valid CSS
