3.2 DOHC Secondary intake runner adjustment #658675 10/22/05 07:52 AM
ProBMXer1313 Offline OP
I have the intake manifold off my truck and I noticed that the butterfly valves for the secondary intake runners don't shut all the way when closed like the butterfly valve on the throttle body. There is a screw on the back of the manifold for adjusting how far the valves close. So should they be adjusted to close all the way or are they supposed to stay open a little bit when closed?
1998 Honda Passport EXL V6 3.2L Auto SOTF 4WD
3" Calmini Lift w/ HD Track Bar, 32x11.5-16 Super Swamper SX, Aisins
[color:"blue"]http://www.CarDomain.com/ID/ProBMXer1313[/color]
Re: 3.2 DOHC Secondary intake runner adjustment [Re: ProBMXer1313] #658676 10/24/05 08:24 AM
Anyone?
Re: 3.2 DOHC Secondary intake runner adjustment [Re: ProBMXer1313] #658677 10/24/05 09:40 PM
SteveV Offline
I don't know for sure if there's supposed to be a gap or not but before you start messing with the setting I would clean it real good with some carb cleaner to see if it seats itself.
1997 Trooper
2002 Rodeo
Re: 3.2 DOHC Secondary intake runner adjustment [Re: SteveV] #658678 10/25/05 03:43 PM
That's the first thing I did after I took it off.
Re: 3.2 DOHC Secondary intake runner adjustment [Re: ProBMXer1313] #658679 10/26/05 03:38 AM
JLEMOND Offline
THE VLV IS NOT SUPPOSSED TO CLOSE ALL THE WAY A GAP FROM 1/16 - AS MUCH AS 1/8 INCH WON,T HURT ANYTHING , YOU WILL NEVER FEEL THE ADJUSTMENT DIFF, IT DOESN,T OPEN UNTIL THE ENG SPEED IS UP AROUND 3600 RPM ANYWAY BUT CAN OPEN AS LOW AS 3000RPM AND IS STRICTLY CONTROLLED BY THE ECM, JERRY
Re: 3.2 DOHC Secondary intake runner adjustment [Re: JLEMOND] #658680 10/26/05 05:43 AM
Ok good, then I don't need to change any thing, Thanks
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6072 MB (Peak: 0.6766 MB) Data Comp: Off Server Time: 2026-10-26 14:03:21 UTC
