2.6 Flywheel #658891 10/23/05 04:20 AM
Rhino58 Offline OP
Was wondering if anyone knows if a 240mm flywheel from a mitsubishi starion will bolt to my 85 Dodge D50 w/ 2.6 engine. Thanks All!
Re: 2.6 Flywheel [Re: Rhino58] #658892 10/23/05 12:14 PM
Yes, it fits just fine. I've done it before. Nice big hefty clutch you get that way, too, huh? I'd change the pilot bearing while I was there.
Re: 2.6 Flywheel [Re: fasteddy] #658893 10/24/05 06:28 AM
powerRam50 Offline
eddy cind of mentioned it but you have to also run a starion clutch.but it all bolts up.
Re: 2.6 Flywheel [Re: powerRam50] #658894 10/24/05 03:32 PM
dadrab Offline
You'll also notice that the Starion flywheel will have a hole in it for a locating pin. Don't panic, but that pin will not be on your crankshaft output. The bolt holes will line up though.
with awesome audio.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6018 MB (Peak: 0.6572 MB) Data Comp: Off Server Time: 2026-11-19 05:34:39 UTC
