Bolts for metal timing chain guide #659011 10/23/05 05:00 PM
F
FarmerTed Offline OP
I'm installing a new timing chain set with the metal guide. The bolts for the stock plastic guide have an unthreaded shoulder, larger diameter than the threaded part, that goes through the thick plastic guide. Do I need new bolts for the new metal guide since its a lot thinner and the mount holes are only large enough for the threaded part of the bolt to go through? I have it bolted up with the original bolts and it seems to hold fine. Any ideas?
1994 4x4 22RE
Re: Bolts for metal timing chain guide [Re: FarmerTed] #659012 10/23/05 05:19 PM
4Crawler Offline
I recall the metal guide kit I got from DOA Racing included new mounting hardware.
Re: Bolts for metal timing chain guide [Re: FarmerTed] #659013 10/23/05 05:21 PM
brentox Offline
I did just what you did with the original bolts. The shoulder seemed to hold just fine against the metal guide, and that was about 50K miles ago.....
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
Re: Bolts for metal timing chain guide [Re: brentox] #659014 10/23/05 05:36 PM
87Toy4x4 Offline
i posted a thread about this a while ago, let me see if i can find it. i bought some new bolts from home depot w/ lock washers and they are holding up.
Re: Bolts for metal timing chain guide [Re: 87Toy4x4] #659015 10/23/05 05:41 PM
87Toy4x4 Offline
Re: Bolts for metal timing chain guide [Re: 87Toy4x4] #659016 10/23/05 07:50 PM
F
Thanks for the replies. It looks like the original bolts will work OK.
1994 4x4 22RE
Re: Bolts for metal timing chain guide [Re: FarmerTed] #659017 10/23/05 11:41 PM
Brian894X4 Offline
I ran into the same problem, and used the stock bolts. It's held up just fine for several years now. But it would probably be best to use the proper size and grade bolt and some locktight.
Re: Bolts for metal timing chain guide [Re: Brian894X4] #659018 10/24/05 01:30 AM
F
I put it back together with the orignal bolts. Hopefully I won't have any problems. Its nice not to hear the sound of the timing chain eating its way through the cover anymore!
1994 4x4 22RE
Re: Bolts for metal timing chain guide [Re: FarmerTed] #659019 10/24/05 02:16 AM
87Toy4x4 Offline
oh yeah i used locktight on my bolts also. i hope you did.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6274 MB (Peak: 0.7296 MB) Data Comp: Off Server Time: 2026-06-17 13:00:25 UTC
