clutch recommandation? #659066 10/23/05 09:46 PM
TrooperMonty Offline OP
My 88 montero is in need of replacing clutch as it is slipping really bad. I'm also planning on putting 32 x11.5 tires. I was told I should get heavy duty clutch set but not sure what to go with...any recommandations?
88 Montero 2.6L 2" Body Lift 32" Geolanders
Re: clutch recommandation? [Re: TrooperMonty] #659067 10/24/05 12:02 AM
LRJ4x4 Offline
either OEM or CenterForce will do. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: clutch recommandation? [Re: LRJ4x4] #659068 10/24/05 03:09 AM
I absolutely love my CenterForce DF in my 87. I am totally bummed that I had the stealer put an OEM in my 95 before I could get to it myself. The CF takes a little muscle, but I am very happy with the way if shifts. A very solid feel that I can shift very smoothly.
Re: clutch recommandation? [Re: MontyMcV] #659069 10/24/05 06:32 AM
powerRam50 Offline
i have been rippin on my beck/arnly for 2 1/2 years with no problems.for a stock replacement this is a great clutch.
Re: clutch recommandation? [Re: MontyMcV] #659070 10/24/05 10:45 PM
I found CenterForce clutches are really expensive though...
Re: clutch recommandation? [Re: TrooperMonty] #659071 10/24/05 10:47 PM
Mine was around $325 IIRC.
Re: clutch recommandation? [Re: powerRam50] #659072 10/24/05 10:49 PM
I was going to order beck/arnly then I found out about Hays Super Brute Clutch kit. They are supposely much better at slightly more price. I got ordered it today for $180 including shipping. Have you guys heard about Hays clutch kits? Part number is 90-600. My mechanic friend tells me I'll need heavy duty clutch to handle bigger tires (32x11.5).
Re: clutch recommandation? [Re: TrooperMonty] #659073 10/25/05 06:18 AM
powerRam50 Offline
the problem with some of the big clutchs(center force) is they dont like to be sliped.they are engaged or not.and some off road situations need that cluch to be sliped.
Re: clutch recommandation? [Re: powerRam50] #659074 10/26/05 02:40 PM
The guy at the 4x4 store where I ordered mine from says the CF on his supercharged Yota has been great. Since I haven't been on the trails yet with mine, I can't comment first hand. I know the Quest guys aren't thrilled with them. But I'm pretty sure those are high RPM dumps at the strip.
Re: clutch recommandation? [Re: MontyMcV] #659075 10/26/05 06:21 PM
dadrab Offline
Better throw in my "for what it's worth" here.
In 17 years, I've replaced the clutch twice. Once because it needed it and the second because I was installing a new engine and thought it folly to do so without a new clutch. I went OE both times and haven't regretted it.
Keep in mind that I don't do a whole lot of heavy wheeling - mostly dirt and mud. And, I'm pretty easy on a clutch, choosing to coast rather than downshift to dump speed; few high-rev clutch dump situations (note I wrote "few" <img src="/forums/images/graemlins/wink.gif" alt="" />); and not much clutching in a higher gear when a lower one will do.
with awesome audio.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6307 MB (Peak: 0.7372 MB) Data Comp: Off Server Time: 2026-06-20 13:42:01 UTC
