clutch recommandation?
#659066
10/23/05 09:46 PM
My 88 montero is in need of replacing clutch as it is slipping really bad. I'm also planning on putting 32 x11.5 tires. I was told I should get heavy duty clutch set but not sure what to go with...any recommandations?
88 Montero 2.6L 2" Body Lift 32" Geolanders
Re: clutch recommandation?
[Re: TrooperMonty]
#659067
10/24/05 12:02 AM
either OEM or CenterForce will do. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: LRJ4x4]
#659068
10/24/05 03:09 AM
I absolutely love my CenterForce DF in my 87. I am totally bummed that I had the stealer put an OEM in my 95 before I could get to it myself. The CF takes a little muscle, but I am very happy with the way if shifts. A very solid feel that I can shift very smoothly.
[Re: MontyMcV]
#659069
10/24/05 06:32 AM
i have been rippin on my beck/arnly for 2 1/2 years with no problems.for a stock replacement this is a great clutch.
[Re: MontyMcV]
#659070
10/24/05 10:45 PM
I absolutely love my CenterForce DF in my 87. I am totally bummed that I had the stealer put an OEM in my 95 before I could get to it myself. The CF takes a little muscle, but I am very happy with the way if shifts. A very solid feel that I can shift very smoothly. I found CenterForce clutches are really expensive though...
[Re: TrooperMonty]
#659071
10/24/05 10:47 PM
Mine was around $325 IIRC.
[Re: powerRam50]
#659072
10/24/05 10:49 PM
i have been rippin on my beck/arnly for 2 1/2 years with no problems.for a stock replacement this is a great clutch. I was going to order beck/arnly then I found out about Hays Super Brute Clutch kit. They are supposely much better at slightly more price. I got ordered it today for $180 including shipping. Have you guys heard about Hays clutch kits? Part number is 90-600. My mechanic friend tells me I'll need heavy duty clutch to handle bigger tires (32x11.5).
[Re: TrooperMonty]
#659073
10/25/05 06:18 AM
the problem with some of the big clutchs(center force) is they dont like to be sliped.they are engaged or not.and some off road situations need that cluch to be sliped.
[Re: powerRam50]
#659074
10/26/05 02:40 PM
The guy at the 4x4 store where I ordered mine from says the CF on his supercharged Yota has been great. Since I haven't been on the trails yet with mine, I can't comment first hand. I know the Quest guys aren't thrilled with them. But I'm pretty sure those are high RPM dumps at the strip.
[Re: MontyMcV]
#659075
10/26/05 06:21 PM
Better throw in my "for what it's worth" here.
In 17 years, I've replaced the clutch twice. Once because it needed it and the second because I was installing a new engine and thought it folly to do so without a new clutch. I went OE both times and haven't regretted it.
Keep in mind that I don't do a whole lot of heavy wheeling - mostly dirt and mud. And, I'm pretty easy on a clutch, choosing to coast rather than downshift to dump speed; few high-rev clutch dump situations (note I wrote "few" <img src="/forums/images/graemlins/wink.gif" alt="" />); and not much clutching in a higher gear when a lower one will do.
87 Montero, bought new, by me - 88/89 intercooled Starion Turbo engine- with awesome audio.
