rust on spark plugs!??!! #659101 10/24/05 12:13 AM
A
Andy_92563 Offline OP
Anyone experienced rust on their spark plugs when they've done the maintenance? Never took my truck 4 wheelin' or anything like that. I just use it as a daily driver.
-Andy
1999 Tacoma Black Limited V6, 4x4,104K,LEER shell cover, deck plate air box amsoil air/oil filters w/ amsoil fluids, bilsteins shocks front & rear
3" toytec coils & AAL, 4 new TOYO tires (31x10.5x15). selling truck to the right price!!
Re: rust on spark plugs!??!! [Re: Andy_92563] #659102 10/24/05 12:40 AM
john_luttrell Offline
Where was the rust? Inside the cylinder or outside the cylinder?
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: rust on spark plugs!??!! [Re: john_luttrell] #659103 10/24/05 01:51 AM
A
I wouldn't know, I just un-screwed the spark plugs to replace them and noticed rust on the threads of the old ones. I was wondering if this is a major problem. My truck has over 92,000 miles.
-Andy
Re: rust on spark plugs!??!! [Re: Andy_92563] #659104 10/24/05 03:45 AM
As long as there was no rust on the spark electrode there is nothing to worry about.
John Luttrell
Re: rust on spark plugs!??!! [Re: john_luttrell] #659105 10/24/05 05:17 AM
A
Thanks guys.
-Andy
Re: rust on spark plugs!??!! [Re: Andy_92563] #659106 10/24/05 08:57 AM
BIGBURLYNAKEDMAN Offline
spread some anti-seize across the threads of the new plugs before you install them, that will stop the problem. Also, some anti-seize compounds have the color of copper (maybe confused with rust?) If the plug came out nice and easy, then it's probably not rust, but if they were tough to break loose, it could just be a little surface rust. Hope this post wasn't too late! <img src="/forums/images/graemlins/kewl.gif" alt="" />
'99 Tacoma Xtra cab V6 TRD
TRD Supercharged, URD 7th injector and 2.2" pulley, 32X11.5 BFG All-Terrains, OME 881 3-inch lift/Toytec AAL, 5100 Series Bilsteins all around, and ProComp 130 lights.
No I'm not some creepy naked guy...
Re: rust on spark plugs!??!! [Re: BIGBURLYNAKEDMAN] #659107 10/24/05 07:28 PM
A
that might just be it, the anti seize gloop. thanks again.
-Andy
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6143 MB (Peak: 0.6914 MB) Data Comp: Off Server Time: 2026-11-18 03:30:12 UTC
