Marine bits #659376 10/24/05 08:00 PM
TobyB Offline OP
I was cleaning out the shop
(see the 'for sale section)
and took a few pictures of the US Marine G54b parts:
[Linked Image] [Linked Image]
if you ever needed to watercool your exhaust, I guess...
Maybe make your Monty engine into a stationary generator?
and a complete no- name 2-bbl carb. It's a nice manifold, but it's not the ubiquitous Weber bolt pattern.
Strange stuff, eh?
Toby
'89 V6 4dr- '4- Doris'
Re: Marine bits [Re: TobyB] #659377 10/24/05 08:48 PM
LRJ4x4 Offline
Is it the heater core? it goes around the exhaust just like the old VW bugs.
Where did you get that stuff?
Re: Marine bits [Re: LRJ4x4] #659378 10/24/05 10:18 PM
FrankR Offline
No, it's a jacketed marine exhaust manifold - cooling water runs through it. From the rusty appearance I'd guess it to be a raw water cooled engine (cooling water is drawn through the hull, circulated through the engine and out the exhaust) as opposed to a freshwater (closed/recirculating/heat exchanger) system.
Frank
Re: Marine bits [Re: LRJ4x4] #659379 10/26/05 10:28 PM
TobyB Offline OP
It showed up on a pallet of 2 engines from a local salvage place. The motors had been sitting outside- I rebuilt the better of the two, and still have the rustier.
They had US Marine stickers on the blocks, non- jet manually- adjusted heads, and the rear adaptor on one. Same cam as the Montero, and clean oil!
One had a 'test' tag on it indicating that it had 20- something hours on it- and the inside looked like it. Timing chains, bearings, cams, etc all looked new. Sadly, with the block damage, I had to change the pistons and rings- but then put 75,000 on the thing, and sold it to a friend who's still driving it.
Frank, they had heat exchangers and purge tanks for the engine water jackets, so I really can't explain the rust. Unless the manifold got seawater and the engine got coolant?
Toby
Re: Marine bits [Re: TobyB] #659380 10/26/05 10:50 PM
FrankR Offline
Probably not - actually, the rust I'm seeing on the outside is normal around salt air, spray and ocean bilge water. The inside of the jacket doesn't look too bad - maybe mostly scale.
One thing I'm glad I don't have to ever do again is boil out a raw water manifold in acid..... nasty process. <img src="/forums/images/graemlins/baby.gif" alt="" />
Frank
Re: Marine bits [Re: FrankR] #659381 10/26/05 11:18 PM
Did it have the same bellhousing bolt dimensions as the later 2.6's? Leads me to thoughts of a divorced tranny....
Re: Marine bits [Re: fasteddy] #659382 11/01/05 03:32 AM
TobyB Offline OP
I dunno...
it looks a bit generic in its flange pattern, now that I think about it.
But it came off a G54b...
Toby
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.6181 MB (Peak: 0.7140 MB) Data Comp: Off Server Time: 2026-07-15 07:11:51 UTC
