remanufactured ax15 #659435 10/24/05 09:59 PM
tomriddle Offline OP
just ordered from man trans. should be here friday. what nasty little things will i find while swapping? as i understand it the top two bellhousing bolts are torex studs? any advice on popping the pilot bearing out? what kind of fluid should i fill the newby with? i have allen head bolts holding the crossmember and i'm betting that they're gonna get me right off to a lame start. wish i could justified the nv4500/atlas II combo but...
94 yj 456gears, detroit locker and 30 spline axles out back, 33" bfgs
Re: remanufactured ax15 [Re: tomriddle] #659436 10/24/05 10:18 PM
BigJim Offline
Hey upstate... If them crossmember bolts look like the NY ones I have seen...WOW! Go out there every 2 hours till you get the new tranny and squirt some thread loosner on them.. If they have not been out in a while and that NY salty junk has been on them they just MAY NOT break loose! Some of them NY bolts simply like where they are and will be resistant to backing out.
Re: remanufactured ax15 [Re: BigJim] #659437 10/25/05 02:00 AM
so you've been to ny jim?! though my rig is really clean i have lotts of torches and with the t-case drop i'm pretty sure i can hack that 1x1 square skyjacker tube and put some surplus in there if i must. i'll definatly fight em to the death. it would be so nice if they'd just come out. saturday i should know for sure.
Re: remanufactured ax15 [Re: tomriddle] #659438 10/25/05 02:31 AM
BigJim Offline
I spent 3 summers in Schroon Lake and another in North Hudson.. It has been a long time since however. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: remanufactured ax15 [Re: tomriddle] #659439 10/25/05 03:43 AM
Since you spent the money to get the new tranny and clutch, the time to get the old stuff out, go the extra step and remove the flywheel and get it resurfaced. Once it is out knocking the old pilot out with a punch is a piece of cake. Just put the new one in AFTER resurfacing.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6064 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-05-29 18:53:44 UTC
