Page 4 of 5 1 2 3 4 5
Re: Help me solve this mystery [Re: regularman] #659595 11/07/05 09:06 AM
fokion Offline
Sinece I am one of the unfortunats to ha ve also an OBD1 car. Kia has a scaner that doew not only puls the truble code byt also can remain connected ad give readings through a test drive. Carefull they have 2, one red one yellow ( that is a mode advanced scaner), this is the one. Mind you ONLY kia haw that scanned AFAIK and you can not find it unles you buy it from KIA for big big big bucks round 2.500$ if i remember correctly from the kiatechinfo site when it was free
Re: Help me solve this mystery [Re: fokion] #659596 11/07/05 01:45 PM
regularman Offline OP
Heck 2500 is more than mine is worth. I just used the jumper wire thing. I keep the wire rolledup in the diagnostic connector housing. Just plug it in and it flashes. One thing that is wrong for the 95 that is shown in the book is the connector. You have to connect it between ground and whta the book says is for the 1.6L engine not the 2.0L engine.
Re: Help me solve this mystery [Re: regularman] #659597 11/07/05 02:05 PM
fokion Offline
the thing is that I dont have the flaching sequence ( if I got it right what you mean)
Re: Help me solve this mystery [Re: fokion] #659598 11/07/05 08:31 PM
I didn't have it either until I moved the jumper wire, then it worked. I think all the OBD1s are supposed to do this. You might try it. I can e-mail a picture of the diagnostic plug and what I am talking about.
Re: Help me solve this mystery [Re: regularman] #659599 11/08/05 11:47 AM
fokion Offline
Sorry I wasnt clear but you see English is not my native language <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
The "how is done" I know. what the flaches mean I dont know
ex. 3short - 1 long is "this" error <- this I dont have
Re: Help me solve this mystery [Re: fokion] #659600 11/09/05 02:00 AM
Having the injectors cleaned fixed mine. I have them flow tested and cleaned. The results were amazing.
Re: Help me solve this mystery [Re: fokion] #659601 11/10/05 01:53 AM
It should be long flashes followed by short. Example 3 long, then 4 short is code 34, or 9 shorts only means code 9 (the code I was getting for ECT when cold).
Re: Help me solve this mystery [Re: regularman] #659602 11/14/05 12:52 AM
Well, it dropped below freezing and that kia starts fine now.
Re: Help me solve this mystery [Re: regularman] #659603 11/14/05 03:18 AM
Whew.... I don't know about you, but that was one heck of an adventure. Thanks for sharing that with us. Our '01 acts nasty when she's cold. That's what lead me to your thread. I'm glad you found the problem <img src="/forums/images/graemlins/smile.gif" alt="" />
<img src="/forums/images/graemlins/baby.gif" alt="" />
Re: Help me solve this mystery #659604 11/16/05 06:39 PM
It probably has the same thing on it somewhere. You might want to swap it out and see if it helps. It was only 17 bucks at advance auto parts. just looking at the old one and tearing it apart, I would say that its possible for these to get off on the resistance for the correct temp and really screw with the running of the thing. It probably would not even give a code as long as the resistance was between 300 and 15000 ohms the ecm would accept it as valid even if it was wrong. The only thing a code is given for is open or shorted.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6403 MB (Peak: 0.7604 MB) Data Comp: Off Server Time: 2026-05-29 17:53:56 UTC
