Supra AFM picture #659724 10/25/05 06:07 AM
Vonka Offline OP
Here's a picture of my Supra AFM and everythings running fine.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Supra AFM picture [Re: Vonka] #659725 10/25/05 08:18 PM
W
Wildcat_4R Offline
Quite a size increase in the openings and flapper size on the Supra AFM. Did you get yours out of an early '82 or did you swap electronics?
1987 4-Runner with a "slightly modified" 22RE
Re: Supra AFM picture [Re: Vonka] #659726 10/26/05 03:03 AM
missouriman Offline
yeh, what year? part number?
thanks
Re: Supra AFM picture [Re: missouriman] #659727 10/26/05 03:15 AM
87Toy4x4 Offline
what kind of gains do you suspect you got out of that? noticeable difference?
Re: Supra AFM picture [Re: 87Toy4x4] #659728 10/26/05 03:18 AM
i asked about the Supra swap at one point and no one knew what i was talking about, which sux cuz i bouth a new 3.0 AFM in thelast year instead of upping it to the supra.... coulda had more power for the same price.
Re: Supra AFM picture #659729 10/26/05 04:39 AM
DirtyHarry Offline
Toyota Moderator
Scott I don't recall when you asked, but I have one of these AFMs in my truck that Jeff Moskovitz swapped the RTE traceboard into. Not sure what sort of gains it made since the truck is not running and a lot of other changes were made at the same time.
Bill where in Hawaii are you located?
Re: Supra AFM picture [Re: Wildcat_4R] #659730 10/26/05 05:22 AM
Vonka Offline OP
Yes,82 Supra & just bolt-on plug-in and bought it for $20 at the Auto Recyclers.
Part #22250-43110
#197100-3020
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Supra AFM picture [Re: 87Toy4x4] #659731 10/26/05 05:34 AM
Vonka Offline OP
When I changed AFM's I noticed that my throttle would take in more air.Also take notice I swapped the battery location.
I dont race it but It accelerates quicker on the low to mid revs.But the best part that its running smooth on the idle to WOT and it is a simple bolt & plug-in modification.I just check the gas mileage and I'm getting 19 MPG.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Supra AFM picture [Re: missouriman] #659732 10/26/05 05:37 AM
Vonka Offline OP
thanks
82 Supra/#22250-43110/ the numbers is placed top & bottom
#197100-3020
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Supra AFM picture [Re: DirtyHarry] #659733 10/26/05 05:39 AM
Vonka Offline OP
Im located on the island of Kauai.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6366 MB (Peak: 0.7601 MB) Data Comp: Off Server Time: 2026-06-07 06:54:46 UTC
