Boost presure? #661077 10/29/05 08:08 PM
EVguy Offline OP
I was just wondering what sort of boost presure is normal in a trooper? I have seen posts here mentioning 12 - 14 PSI?
The 2.8 4JB1-TC in my Jeep will go up to about 8 PSI but this engine is out of a bigger truck and maybe they limit it in some aplications more than others?
My gauge sensor is at the intake manifold.
Thanks
Randy
Isuzu 4JB1-TC diesel / Jeep Grand Cherokee conversion
http://www.canev.com/Jeep.html
Isuzu 4HF1 Diesel / 99 Dakota 4X4 conversion
http://www.canev.com/Dakota.html
Re: Boost presure? [Re: EVguy] #661078 11/02/05 04:46 AM
Dougal Offline
The turbomaster pages list two pressures for the turbo wastegate used on the 2.3
http://www.turbomaster.info/despieces_garrett/466272-0002.php
On my 4BD1T the wastegate originally needed 20psi to open it (20 is only just acheivable). I've moderated this to 15psi and the engine runs much better with less backpressure.
IMO trying to run more than 12psi without an intercooler is futile. The extra heat in the air and it's resulting expansion mitigates the extra boost and leaves you with only a few percent extra air molecules for a lot of extra restriction on the engine exhaust.
Re: Boost presure? [Re: EVguy] #661079 11/02/05 05:32 PM
Steve in VA Offline
My Trooper C223T runs 10 psi boost, foot on the floor at 3000rpm. I use 3000rpm as red line.
Steve
Re: Boost presure? [Re: Steve in VA] #661080 11/04/05 05:39 PM
TX76513 Offline
+10 is just making heat unless you can intercool AND increase the pump volume. Without increased pump volume you are just wasting time.
86 Isuzu Trooper TD 5 speed
82 Isuzu Diesel I-Mark
86 300 SDL MB 126
85 300SD MB 126
82 300 D MB 123
Re: Boost presure? [Re: TX76513] #661081 11/05/05 07:50 PM
EVguy Offline OP
I do have an intercooler and have turned up the pump.
BFN
Randy
Re: Boost presure? [Re: TX76513] #661082 11/08/05 04:09 AM
Dougal Offline
Not quite, the extra boost increases the compression ratio.
Re: Boost presure? [Re: Dougal] #661083 11/08/05 10:19 PM
TX76513 Offline
More compression = heat. Need boost and fuel
86 300 SDL MB 126
85 300SD MB 126
82 300 D MB 123
Re: Boost presure? [Re: TX76513] #661084 11/09/05 04:08 AM
Dougal Offline
The efficiency of your engine is directly related to the compression ratio. A higher compression ratio will give you more power out for the same fuel in.
Re: Boost presure? [Re: Steve in VA] #661085 11/09/05 06:45 AM
My dad's '86 P'up with a C223T runs about 14psi from 2200RPM on. It's all stock, other than the motor being rebuilt. Definitely can tell when the boost comes in.
Re: Boost presure? [Re: Dougal] #661086 11/11/05 05:44 PM
TX76513 Offline
Yes and to get more compression you need more fuel not just boost. You can achieve more fuel by adjusting the alda but only to a certain point. To move into the higher boost ranges and have effective results the pumps need to be modified to produce more fuel (beyond the mfg specs).
86 300 SDL MB 126
85 300SD MB 126
82 300 D MB 123
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6334 MB (Peak: 0.7567 MB) Data Comp: Off Server Time: 2026-06-23 08:43:17 UTC
