Differences in power steering pumps... #661529 10/31/05 04:36 AM
F
FarmerTed Offline OP
A couple of junk yards in my area have trucks with complete power steering systems that I want to install on my truck. One set has a switch or something screwed on top of the pump with two vacuum lines coming out of it. The other dosen't. What's the switch for? The set without the switch is a lot cheaper, so I want to get this one. I just want to know if I need this switch or not. Both trucks were fuel injected. Mine is a 94 4x4, 22re.
1994 4x4 22RE
Re: Differences in power steering pumps... [Re: FarmerTed] #661530 10/31/05 05:07 AM
4Crawler Offline
That is the Vacuum Switching Valve (VSV) for the idle-up valve atop the 22RE intake (if present). That idle up valve is used for p/s and A/C, if you have neither, then you may not have the idle-up VSV. Makes no difference in the pump operation, you can leave the VSV disconnected from the intake if you want.
It is sort of a useless feature, my '85 had one of those vacuum lines plugged with intake goo, I cleaned it out and I don't think I ever noticed that the idle ever bumped up when I turned the steering wheel. My new pump has no such switch and it works fine. If the steering needs some help at idle, a blip of the gas pedal is usually all you need to boost the fluid pressure.
Re: Differences in power steering pumps... [Re: 4Crawler] #661531 10/31/05 05:39 AM
F
Thanks for the reply. Looks like I'll go after the one without the VSV and save a few bucks!
1994 4x4 22RE
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5945 MB (Peak: 0.6482 MB) Data Comp: Off Server Time: 2026-06-20 20:22:44 UTC
