Temp OK but no heat for defrost #661569 10/31/05 01:23 PM
Spacetrucking Offline OP
Posting for a buddy's '88 4Runner.
Tried burping the system of air with truck pointing
up on incline, removed heater return hose couple times, tried backflushing with garden hose, rear heater works fine, head gasket fine.
Floor trap has warm air, defrost lukewarm at best,
rear heater piping hot!
What gives?
Thanks!
Hugh
'86 SR-5 Extra-cab 4 x 4, 2" BL, 33 x 12.5 x 15R M/T on 15 x 8 rockcrawlers ( 3 3/4" BS ), 22RE 5 sp , 4.88's Detroit True-Trac front, V6 open rear, 24 mm Sway-Away + Rancho 5000's, removed sway bar, no-rust south US bed, Ramsey 8000 winch
Re: Temp OK but no heat for defrost [Re: Spacetrucking] #661570 10/31/05 03:35 PM
sindersblue Offline
I had this problem in my turbo truck. As it turns out, the PO was dumping Bars leaks in it regularly atempting to fix a crack on the top rad tank. All that did was clog the heater core. I first tried the garden hose and found that the core was severely cloged and flowed very little. Some stuff that looked like urathane sealant came out. So I filled the core and the return hose up w/water and put some compresed air to it(be sure to use low pressure). That did the trick. Tons of stuff flowed out. Heater works great now. Good luck. <img src="/forums/images/graemlins/cheers.gif" alt="" />
"If you can't learn to do something well, learn to enjoy doing it poorly".
85 22RE, 5spd 4Runner project
87 Turbo Truck, Boost Controller, otherwise stock... for now.
86 Turbo 4Runner, Project
Re: Temp OK but no heat for defrost [Re: Spacetrucking] #661571 10/31/05 06:23 PM
check the linkage to the controls and at the Box.
on my 85 the cable fell of the air damper and it was stuck on warm. or check to make sure the water valve on the firewall is not stuck...............Karl
Re: Temp OK but no heat for defrost #661572 11/01/05 01:39 PM
Thanks Guys! I'll try / look it over next weekend.
Hugh
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5968 MB (Peak: 0.6551 MB) Data Comp: Off Server Time: 2026-06-07 07:03:14 UTC
