Rear lift... blocks vs. add a leaf #662596 11/02/05 06:10 PM
I need help deciding what to get to lift my rear a few inches. For the front, I'm doing 3" spacers. I read that add a leaf only lifts about 2"... so would that even look right?
This truck is my daily driver... I usually have an empty bed, but on occasion, I will need it to be able to carry some heavy stuff like lumber, cement blocks... but again, only once in a while.
Re: Rear lift... blocks vs. add a leaf #662597 11/02/05 10:53 PM
Mark in AZ Offline
Toyota Moderator
The tacos are a little high in the back anyway, so 2" will probably leave you level. It's really hard to recommend blocks, but the AAL will be pretty stiff. Oh well, it is a truck now, isn't it <img src="/forums/images/graemlins/kewl.gif" alt="" />
Exploring in a T4R Ltd V8
Re: Rear lift... blocks vs. add a leaf #662598 11/02/05 10:56 PM
tacomajsc Offline
I have added 3in add-a-leafs and it rides real rough. The twos will not be as bad. I have had people tell me not to go with the blocks. I guess they have problems out fourwheeling. I don't take mine off road to much but still staying with the add-a-leaves. I can get a standard inspection sticker the way it sets. So much easier then getting the lift sticker.
My signature has been removed.
Re: Rear lift... blocks vs. add a leaf [Re: tacomajsc] #662599 11/02/05 11:00 PM
Mark in AZ Offline
Toyota Moderator
What does your state make you do when lifted?
Re: Rear lift... blocks vs. add a leaf #662600 11/02/05 11:09 PM
john_luttrell Offline
You can go with up to 3" blocks in the rear with out any problems on or off road, and they will not make the ride stiffer. Anything more than 3" blocks will require some sort of traction/ladder bars to keep the axle wrap in check.
John Luttrell
2001 4x4 short cab, 3 inch lift with 33 inch mudders and Powertrax no-slip in the rear
1991 Jeep YJ, 4 inch suspension lift on 33" BFG's
Re: Rear lift... blocks vs. add a leaf [Re: Mark in AZ] #662601 11/03/05 06:28 PM
tacomajsc Offline
They make you get a lift sticker. The check over your truck more then a standard inspection. The lift sticker cost more also, i am not sure on the price.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6047 MB (Peak: 0.6736 MB) Data Comp: Off Server Time: 2026-11-01 16:24:20 UTC
