No light in temp panel in '89 Montero #662977 11/03/05 09:36 PM
Ritchie1 Offline OP
Can anyone tell me how to remove the temp face palcte to seeif I have a disconnected or burned out bulb on my '89 montero? I tried to remove the housing that surrounds the cassette/radio, clock, lighter and temp panel but can only find two screws at the bottom ob both sides. These screws don't release the entire housing.
1989 Montero V6 Automatic. All stock in immaculate condition. New comer to the scene and want to learn more!!
Re: No light in temp panel in '89 Montero [Re: Ritchie1] #662978 11/03/05 10:44 PM
MarkG Offline
The console has two screws at the top. One in each corner.
Re: No light in temp panel in '89 Montero [Re: MarkG] #662979 11/07/05 07:55 PM
All that panel is lit by one bulb, I think, and it uses fiber optic light hoses to take the light to the faceplate. You have to take scads of stuff loose to get it all the way out...
Re: No light in temp panel in '89 Montero [Re: fasteddy] #662980 11/08/05 01:29 AM
Oh man, I was looking forward to an easy fix for this. My panel light doesn't work either and it's a pita in the dark. The lights at the ends of the adjustment stalks work, but I can't see the panel. Guess I will have to stay with using the dome light to see or maybe keep a flashlight handy!
Re: No light in temp panel in '89 Montero #662981 11/08/05 04:40 AM
But I don't think you have to take it all the way out...
Re: No light in temp panel in '89 Montero #662982 11/11/05 10:54 PM
Ritchie1 Offline OP
I figured it out. Two screws at the top and four screws at the bottom (2 on each side after you remove the small pop out covers. You need to make sure to remove the plastic plate that surrounds the 4WD shifter, since this will facilitate the removal of the temp/radio/lighter/clock unit. Once removed , pull carefully forward and look for the wire that leads to the white casing in the middle. Pull the black socket out and replace with a Sylvania 74 bulb ( avialable at Kragen's for $2.49). FYI the local Dealer wanted to charge me $22 for the bulb and $150.00 to replace it !!! What a scam <img src="/forums/images/graemlins/nana.gif" alt="" /> I'll try to attach some pics if I can. The whole job should take less than hour.
Ricardo
Re: No light in temp panel in '89 Montero [Re: Ritchie1] #662983 11/12/05 03:25 AM
Cool!! I am going to get in there and get that thing fixed too! Thanks for figuring it out <img src="/forums/images/graemlins/kewl.gif" alt="" /> Dang stealers. I know they need to make a profit on parts, but a mark-up that much is criminal <img src="/forums/images/graemlins/angry.gif" alt="" />
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.010s) Memory: 0.6147 MB (Peak: 0.6923 MB) Data Comp: Off Server Time: 2026-11-18 03:31:23 UTC
