Page 1 of 3 1 2 3
SAS dudes post up pics of Steering please #663156 11/04/05 05:17 PM
paulevans76 Offline OP
If possible, I'd like to see your draglink angles from the side, in front, below/above. list how far forward your axle is from stock, problems you ran into, solutions you came up with, things you would change.
muchas gracias <img src="/forums/images/graemlins/cheers.gif" alt="" />
88 Troop - Posing yard art
Re: SAS dudes post up pics of Steering please [Re: paulevans76] #663157 11/04/05 06:48 PM
RobG Offline
Orginal Setup: Hi-Steer, D44, original suspension
not enough seperation between tie rod and drag link. hit the pitman arm during compression.
Setup #2: Crossover, D44, original suspension
Setup #3: Hydro-Assist Crossover, D44, modified suspension (axle furthur forward than orginal)
Currente Setup: Hydro-Assist behind the knuckle crossover, D60, modified suspension (axle furthur forward than orginal)
-Rob
Re: SAS dudes post up pics of Steering please [Re: RobG] #663158 11/04/05 08:52 PM
awesome, thanks rob. did you move your steering box at all? is that the stock pitman? how far forward are you?
I'm kinda trying to see how far forward I can move the axle while keeping the box in it's place w/out a crazy drag link angle.
Re: SAS dudes post up pics of Steering please [Re: RobG] #663159 11/04/05 09:36 PM
Nick Offline
Rob are you still using the Isuzu steering box with the D60?
'99 Trooper 3.5L->R150F->Duals->4.7->60/14b->38.5s
'96 Trooper DD
Re: SAS dudes post up pics of Steering please [Re: paulevans76] #663160 11/04/05 09:37 PM
RobG Offline
steering box is in stock location. pitman arm is stock isuzu. 1st time I drilled out the taper and ran SRE's. Now I'm using the stock arm/taper and running the F250 TRE upside down.
axle placement was probably around ~5" forward first time around, and then an additional 4" or so for a total of 9" the second time.
-Rob
Re: SAS dudes post up pics of Steering please [Re: RobG] #663161 11/04/05 09:39 PM
RobG Offline
yes, still a stock isuzu box turning 38's. I had Matt @ westtexasoffroad do the taping/porting for hydro assist.
I'm now thinking i'm going to move to a different steering box (more common Jeep, Chevy, etc) to get some more performance out of my hydro assist setup.
-Rob
Re: SAS dudes post up pics of Steering please [Re: RobG] #663162 11/04/05 10:09 PM
I'm looking at a possible 8" forward or so and just looking at the pitman to where the steering arm would be looks like it would be a crazy angle. I might just try not to move it that far. I'd have to redrill my main leaves and loot the leaf bin to make some hybrid spring packs, but I'm still looking 5-6" forward because of how I will be mounting them.
My main goal here is when I get the rest of my parts together, minimum downtime. I'd rather not have to mess with the box (moving it or swapping it) so I can focus on everything else. I want to get wheelin <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: SAS dudes post up pics of Steering please [Re: paulevans76] #663163 11/04/05 10:34 PM
RobG Offline
if you look at that last picture of mine, you'll see my steering angles forward a good bit as a result of my axle placement. while not ideal, it certainly isn't a totally crazy angle (and remember, thats like 9" forward placement of the axle)
when I look at swapping steering boxes, I'm going to bring the new one forward a bit to get the links to more parallel
-Rob
Re: SAS dudes post up pics of Steering please [Re: RobG] #663164 11/04/05 11:07 PM
im wondering if the box placement in my 1st gen troop is different than your rodeo....
Re: SAS dudes post up pics of Steering please [Re: paulevans76] #663165 11/04/05 11:21 PM
Bansil Offline
RobG,
Who's steering arms are you using now?
TIA
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.014s Queries: 16 (0.009s) Memory: 0.6414 MB (Peak: 0.7631 MB) Data Comp: Off Server Time: 2026-11-02 14:11:48 UTC
