Hot n Cold. #663337 11/05/05 01:53 AM
4X4_Canuck Offline OP
Hey all,
Anyone up to snuff on the heating system? At max heat ( No AC system ) I get hot air beside the console on the driver's side and cold air beside the console on the passenger side..
Are there 2 heating elements and one is burnt out? is it easy to replace? Re-circulating air wamrs thing a bit but still a noticable temperature differential side to side.
Thanks !
<img src="/forums/images/graemlins/drunk.gif" alt="" />
-Drew
91 SWB V6 Raider. (Japan)
R/H Drive. Rear Lock.
32x11.5 BFG A/Ts w/ 15x8 rims
1000 watt Kenwood amp w/ 2 10"JBLs
Re: Hot n Cold. [Re: 4X4_Canuck] #663338 11/05/05 05:04 AM
LRJ4x4 Offline
Just one heater core that takes hot anti-freeze from the engine and blows a fan over it. Do you have the fan on outside air or circulating?
Re: Hot n Cold. [Re: LRJ4x4] #663339 11/05/05 05:26 AM
NHMonty Offline
could it be that littel switrch unique ot monteros? There is a little lever on the vents that allows you to allow air from outside to that one vent and not the other. Ill be one is set to open and the other to internal.
1990 RS 4door 3.0L V6. 2 inch body lift. 33x12.50/r15 BFG AT's, 3 Superswampers(1 on the way) CD Player, Superwinch Hubs
My pics http://community.webshots.com/user/nhmonty
Re: Hot n Cold. [Re: 4X4_Canuck] #663340 11/05/05 06:06 AM
don Offline
...are all the little plastic ducts in place??
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Hot n Cold. [Re: don] #663341 11/05/05 05:34 PM
BobShaw Offline
If nothing else works, remove the side pannels at your feet and see if you have a rust thru holes there. I had one in my D50 and my wife complained about cold air.
Bob Shaw
Re: Hot n Cold. [Re: BobShaw] #663342 11/07/05 05:23 AM
Thanks for the ideas, I'll have a closer look. It is on outside air where it is most noticable. I thought i had both vents switched to fan/ air combo as it seems to flow more but I'll double check.
BRB,
Drew
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6115 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-06-10 06:26:56 UTC
