isuzu trooper question #663655 11/06/05 06:03 PM
does anyone make fender flares that i can bolt onto a 1993 isuzu trooper? i've got a bit of rust around the lower edge of the fenders, and i want to cut it out, and put a flare on to make it look nicer. i dont want really wide ones though, so i need a bit ofhelp. thanks in advance
Re: isuzu trooper question #663656 11/06/05 06:42 PM
Jessica Offline
you can ask DanielT about this... he at one time was wondering on fiberglass Trooper flares.
http://www.4x4wire.com/forums/showf...&o=&fpart=1&vc=1
-Rob
Re: isuzu trooper question [Re: Jessica] #663657 11/06/05 07:16 PM
onebadtrooper Offline
Sence Its a 93, its a second gen. You could put on some fender flares from a newer trooper. Also Bushwhacker makes then for second gens, aswell as Calmini. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: isuzu trooper question [Re: onebadtrooper] #663658 11/06/05 09:21 PM
what years will this work for?
Re: isuzu trooper question #663659 11/07/05 03:40 AM
langforg Offline
Bushwacker flares will work with troopers from 92-97. However, I don't know how well they will work since you mentioned cutting out part of the fender. I did that on my 95 and ended up going with some generic rubber fender flares.
Brad
95 Trooper,3in Lift,15x10 AR-23 Wheels, 33x12.50 BFG AT's, SuperWinch Hubs,Rock Sliders,Tie-Rod Shields,Cross-Drilled Brake Rotors,ARB Bull Bar...,looking for cheap winch.
Re: isuzu trooper question #663660 11/07/05 03:43 AM
Bigpoppax2 Offline
92 and up should work.
Re: isuzu trooper question [Re: langforg] #663661 11/07/05 04:00 AM
here's the calmini's
calmini flares
Re: isuzu trooper question [Re: onebadtrooper] #663662 11/08/05 03:37 PM
yea those flares are a bit spendy. what are options as far as color matche'd paint? i think i may just grind down the rust, and fill it in, and paint it.
Re: isuzu trooper question #663663 11/08/05 09:41 PM
CPOM Offline
You can get a quart or two custom mixed at an autobody supply shop if you give them the paint code found on the firewall sticker. Expensive though.....
CHRIS
98 Amigo, 92 Pup
Re: isuzu trooper question [Re: CPOM] #663664 11/08/05 10:04 PM
Bigpoppax2 Offline
And he ought to know as he I'm sure bought a few quarts with all the different crap he went through getting his 98 on the road. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Joe
PHP: 7.4.33 Page Time: 0.015s Queries: 16 (0.011s) Memory: 0.6351 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-11-02 12:30:14 UTC
