Re: cd player wont fit [Re: Greg_Canada] #663711 11/07/05 02:34 AM
CraShYota Offline
they should all fit i got a stereo and my cb cramed in there.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: cd player wont fit [Re: CraShYota] #663712 11/07/05 03:20 AM
BAZ Offline OP
i dont know what this sleeve is everyone's talking about. apparently i dont have one or something
1994 Toyota X-Cab 4WD 22R-E 5 speed.
Re: cd player wont fit [Re: BAZ] #663713 11/07/05 06:21 AM
The sleeve comes with aftermarket stereos. I discarded the sleeve and used a mounting kit on my wifes Truck. It was easy. Just go to Circuit City or Crutchfield and get the kit for your truck and stereo. Youll be glad you did.
Re: cd player wont fit #663714 11/07/05 05:26 PM
tucker80 Offline
If you are replacing the OE radio, then when you removed it from the dash, you should have had to unscrew 4 gold colored screws and removed the radio and the small pocket as an assembly. If you look at the side of the OE radio you will see that it has two screws in each side. You should be able to uncrew those and the OE head unit should slide out. Then you can take your new head unit and slide it in. Most, if not all, aftermarket decks have threaded holes in the sides and you should be able to line up a couple of them and bolt your deck into the factory bracket.
You may have to play with it to get the depth right. the pocket is held to that same bracket by a couple of screws and you shouldn't have to remove it. Then you just slide the whole assembly back into the dash and bolt it back in.
It is a very secure mount and it is really hard for a would be theif to steal it. Believe me, I came out one morning to a busted window, no speakers and a trashed dash, but the radio was still there. Had to have pissed them off.
Anyway, the sleeve that everyone is talking about usually comes with the radio and it slides up around the unit and in most vehicles you slide it into the dash opening and bend some little metal tabs up to secure it behind the tirm panel. If you use the factory assembly, then this sleeve is not needed and can be discarded.
Hope that helps,
Matt
'90 Pickup 22RE 4.30's, 31 STT's, MossyRock Sliders
'90 2wd xtraCab, getting a heart transplant
'88 4Runner with a thrown rod, waiting in the wings
Re: cd player wont fit [Re: tucker80] #663715 11/17/06 09:55 AM
TxMiniTruck Offline
Tucker is right I just finished a cd install in my 87 pickup yesterday evening and I used the factory brackets and did not incur any fitment problems other than getting the wiring positioned at the rear if the radio when I first installed it.
Use the factory brackets and and dont use the sleeve with the stario and you will not have any problems along with it being a very stable install.
Damon
Paris Tx.
Damon
N.E. Texas
Re: cd player wont fit [Re: TxMiniTruck] #663716 11/17/06 11:05 PM
rovers1973 Offline
I used a kit with mine that had a pocket below the deck, and it worked fine. You can't use the little faceplate outer trim though. Other that that it works great.
91 SR5 Xtra Cab, 298000km, 4" lift, 56" rear springs, 33-12.5R15 BFG Mud-Terran T/A KM2.....and an '85 axle still waiting to go in.
Re: cd player wont fit [Re: rovers1973] #663717 11/18/06 02:57 AM
TxMiniTruck Offline
I used the factory face plate with the factory pocket below the radio and it worked fine.
Damon
N.E. Texas
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6202 MB (Peak: 0.7150 MB) Data Comp: Off Server Time: 2026-06-07 08:27:38 UTC
