ABS fuse? #663953 11/07/05 05:32 PM
ralleyclimber Offline OP
Good morning,
When I was changing out my spark plugs, I checked my fuses and yup I need some more (spares). And while I was under there, I noticed that there is a slot for an ABS fuse. Does that mean that my 1995 Tacoma V6 SX, has ABS? I looked at the othere slots that are there for future things and they did not have any connectors in there like the ABS one did.
Thanks guys,
ralleyclimber
Re: ABS fuse? [Re: ralleyclimber] #663954 11/09/05 07:28 PM
Do I make sense?
Re: ABS fuse? [Re: ralleyclimber] #663955 11/09/05 10:35 PM
probably was an option...i know my truck doesnt have it because theres no contacts for the abs fuse in the fuse box...also you can tell by when you start the vehicle the abs runs diagnostics on itself at start up...one of the tests is a bulb check...so if the abs light comes on at start up it means you have it.
Re: ABS fuse? #663956 11/10/05 05:29 PM
There are contacts for the ABS fuse in the fuse box. But when I start it there is no ABS light coming on the dash.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5971 MB (Peak: 0.6547 MB) Data Comp: Off Server Time: 2026-06-07 06:34:01 UTC
