fuel pump.......where and what brand is good to buy? #664502 11/09/05 03:57 AM
I
islandpsd Offline OP
my 85 fuel pump is finally shot. its starting to leak oil. where is the best place to buy a replacement? any brand i should stay away from?
1985 Toyota 4x4 22R straight axle, Stock height, Original owner
Re: fuel pump.......where and what brand is good to buy? [Re: islandpsd] #664503 11/09/05 06:23 PM
fourwd1 Offline
Is it mechanical (carb) or electric (EFI) ?
I've never had any luck w/aftermarket mech pumps for a 22R.
Used TOYOTA mech pumps work better than an aftermarket unit in my experience.
- seen in FOUR WHEELER mag July 2006 & OFF-ROAD mag Feb 2007 -
'84 4Runner ARBed 5.29s F&R,4.7 & 2.28 t-cases,hy-steer,BudBuilt skid,30spl Longs,36" TSLs,Chevys
'83 P/U, Buick 231 V6,Holley 4 bbl,Weiand intake,Downey headers,TH350 w/700R4 gearset
Re: fuel pump.......where and what brand is good to buy? [Re: islandpsd] #664504 11/09/05 07:06 PM
ZUK Offline
Bapp Imports is probably trustworthy....
mostly stock
Re: fuel pump.......where and what brand is good to buy? [Re: ZUK] #664505 11/10/05 07:24 AM
4WD22R Offline
A buddy of mine had the same problem and he just fabbed up a cover for the mechanical pump mount and cut out a gasket and sealed it up. Then added a genaric eletric fuel pump from BAP and put it inline with the fuel line. works great, he even installed a small kill switch so he can turn off the pump when the truck is parked, making it hard to get very far if someone steals it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: fuel pump.......where and what brand is good to buy? [Re: islandpsd] #664506 11/10/05 07:30 AM
kewlynx Offline
If you're carbed, I just got a fuel pump from NAPA; $42. So far so good. My original finally crapped out; 376K on the dial.
4WD22R-- I know of which he speaks; it's peein' out the weep hole in the bottom; ain't the spacer. I was hopin' it was the gasket too, but wasn't that lucky.
**ubi apis- ibi salus**
Re: fuel pump.......where and what brand is good to buy? [Re: kewlynx] #664507 11/10/05 07:58 AM
4WD22R Offline
Yeah, I don't think I'm ever that lucky either... I kinda like the idea of an eletrical pump instead of a mechanical one, throw a pressure regulator on it and your golden, works great for mine stock aisan carbs and my buddys, twin turbos, and 4 side draft 40mm motorcycle carbs.....(yeah he's a street guy <img src="/forums/images/graemlins/barf.gif" alt="" />) <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: fuel pump.......where and what brand is good to buy? [Re: 4WD22R] #664508 11/10/05 08:09 AM
kewlynx Offline
The benefit of that is that you get to go a little more vertically.
But hey, I just scored a COMPLETE (finally) '90 EFI system.
Hmmmm....mebbee the earlier stuff I've been ratholin' can go on the 83......(gleefully rubbing hands together)...
Somebody slap me; gotta take care of one thing at a time here.... <img src="/forums/images/graemlins/shiner.gif" alt="" />
Too many Yotas, not enough time, and no garage.... <img src="/forums/images/graemlins/baby.gif" alt="" />
Re: fuel pump.......where and what brand is good to buy? [Re: kewlynx] #664509 11/10/05 08:18 AM
Happy Birthday 87Toy4x4 Offline
i was wondering if it was my imagination or not when my truck didnt stall out half as much when at steep slopes after the new carter electric fuel pump. but this was also the same time i had my new eb head and cam put on. so i wasnt sure what part made my truck not stall as much.
Re: fuel pump.......where and what brand is good to buy? [Re: kewlynx] #664510 11/10/05 08:19 AM
4WD22R Offline
Lucky! I vetoed the EFI swap when I rebuilt the motor last time cause it was expensive/hard to find the parts.....float some of those parts this way.... <img src="/forums/images/graemlins/smile.gif" alt="" />
i've got the opposite problem, not enough time, not enough money only one Yota but i do have a garage!!!! <img src="/forums/images/graemlins/nana.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6325 MB (Peak: 0.7357 MB) Data Comp: Off Server Time: 2026-05-29 22:16:14 UTC
