Page 1 of 3 1 2 3
Need to re-index steering wheel #664903 11/10/05 04:21 AM
W
Wareagle Offline OP
MY steering wheel got pretty tweaked at Uwharrie. Aside form disconnecting battery and removing screws that hold in airbag, is there anything special that I need to do to straighten wheeL?
Re: Need to re-index steering wheel [Re: Wareagle] #664904 11/10/05 05:38 AM
Rodeo Guy Offline
IIRC, disconnecting the battery doesn't necessarily disable the airbag. I would definately read up in the manual, or find out online the correct procedure for disabling, and equally as important, re-enabling the airbag.
Other than that, rent a puller from Napa and have at it.
Mike
"Damn the carnage! Full throttle ahead!"
95.5 rodeo, 37" Trxus MT, dana 44/9", coil-overs, lockers..... http://www.cardomain.com/memberpage/550454
Re: Need to re-index steering wheel [Re: Wareagle] #664905 11/10/05 06:03 AM
96TrooperSE Offline
Yeah, you want to be very carefull around the airbag. Just a static shock can set one off. We set one off in Auto Electonics class and it was like a shotgun going off. Lookup the proper procedure in a repair manual.
/1996 Trooper SE\
OME 912's w/2.5" spacers, Superwinch hubs, 265/75R16 Yokohama Geolanders (street), 34x10.50x15 Super Swamper LTB's, Indy4x HD Tie Rods, Indy4x Rock Sliders
Re: Need to re-index steering wheel [Re: 96TrooperSE] #664906 11/10/05 12:01 PM
Iluvmud Offline
The proper procedure is to dissconet the battery, then pull the fuse, and finally disconet the air bag wiring harness (big yellow thing, can't miss it). I am gonna have to do the same thing this weekend. We did an alinment in class and got it perfect, except the steering wheel is about 2 degress off. <img src="/forums/images/graemlins/shiner.gif" alt="" />
8 inches of lift, 33s, custom bumpers and rockbars, powertrax, T-maxx 9000, lots o lights, and some bass in the trunk
Lifted, locked, and ready to rock!!! <img src="/forums/images/graemlins/evil.gif" alt="" />
[url=http://www.cardomain.com/memberpage/743285][/url]
Re: Need to re-index steering wheel [Re: Iluvmud] #664907 11/10/05 01:21 PM
litnin Offline
You are also supposed to wait 10 minutes (I think is the time frame) after disconnecting the battery before disconnecting
anything else.
The air bag system remains charged and armed for a certain period of time (I'm thinking it was 10 minutes) after
the ignition system is turned off or the battery is disconnected.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: Need to re-index steering wheel [Re: litnin] #664908 11/10/05 02:13 PM
Jessica Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> Insert image of me trying to get the steering wheel off while not putting my head or a body part in front of the airbag just in case.
Mark, What they all have said is right. It's kinda nervewracking though! And actually the driver's was much easier to deal with than the passengers. Just remember, once it's out, don't sit on it, kick it or drop tools on it till you get it back in <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Need to re-index steering wheel [Re: Jessica] #664909 11/11/05 02:16 AM
W
Wareagle Offline OP
Thanks all! SO basically, It sounds like disconnect battery, hit brake light and wait a while so electrical chares are spent, pull 4 bolts, disconnect airbag, then remove. I guess nest part is unbolting wheel then using a puller to remove wheel?
Re: Need to re-index steering wheel [Re: Wareagle] #664910 11/11/05 02:53 AM
Jim_Paget Offline
It really sounds to me as though the problem isn't the steering wheel. I don't think that there is any way to "tweak" just the steering wheel. I sounds to me as though there is something bent in the steering linkage, such as the center link. There just isn't anything that you can do to just tweak the steering wheel.
Think about how the system works. The wheel is splined onto the shaft which goes to the gear box. It is a solid connection all the way through. If the wheel no longer is aligned as it used to be, something had to bend or break.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
Re: Need to re-index steering wheel [Re: Jim_Paget] #664911 11/11/05 02:58 AM
W
Wareagle Offline OP
Suspension looks fine. No pulling or reconizably bent steering parts. Wheel is clocked atleast 15 degrees. I wasn;t sure if the wheel was splined or not. All 3 of my 2nd gens seemed to have wheel knocked out of alignment rather easily.
Re: Need to re-index steering wheel [Re: Wareagle] #664912 11/11/05 03:15 AM
Jim_Paget Offline
I have seen at least one Isuzu if not two that had a twisted output shaft on the steering gear box. It was pretty hard to spot until the pittman arm was pulled. There was also a 2nd Gen Trooper at Moab that had a bent centerlink that exhibited the same symptoms.
Jim Paget
www.rrr4x4.com
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6405 MB (Peak: 0.7651 MB) Data Comp: Off Server Time: 2026-11-03 12:28:30 UTC
