On the Road Again...YES!!! #665049 11/10/05 08:08 PM
RSMonty Offline OP
<img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
A big thanks to all who helped me get my '91 back on the road! <img src="/forums/images/graemlins/cheers.gif" alt="" /> Especially Grass13,FrankR,TobyB. With her Frankenstein transplanted brain/ecu (thanks Grass!) , she turned right over! <img src="/forums/images/graemlins/kewl.gif" alt="" /> A special thanks to FrankR for checking the ecu info for me!
Of course my enthusiasm and excitement gave me overconfidence. I ran the truck right over to the inspection station since it was 5 months overdue. But even with her purring like a kitten, she failed for emissions!!! <img src="/forums/images/graemlins/frown.gif" alt="" /> <img src="/forums/images/graemlins/scared.gif" alt="" />
But I'll tackle one thing at a time.
<img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: On the Road Again...YES!!! [Re: RSMonty] #665050 11/10/05 08:22 PM
grass13 Offline
once again congrats <img src="/forums/images/graemlins/cheers.gif" alt="" />. post your emmisions results and im sure that some of the sharper tacks... (HEY FRANK!!) can figure it out. and now i guess we know for sure that a 90' cali ecu will work in a 91' federal... so much for stealer knowledge <img src="/forums/images/graemlins/rolleyes.gif" alt="" />.
Re: On the Road Again...YES!!! [Re: grass13] #665051 11/10/05 08:26 PM
87Montero Offline
Maybe that's why he's failing emissions! <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: On the Road Again...YES!!! [Re: 87Montero] #665052 11/10/05 09:02 PM
RSMonty Offline OP
Gas-----Standard-----Reading-----Result
NOx-----990---------1456----------Fail
HC------147----------329----------Fail
CO------1.24--------2.24----------Fail
Co2------------------13.2
O2--------------------.4
Re: On the Road Again...YES!!! [Re: RSMonty] #665053 11/10/05 09:27 PM
LRJ4x4 Offline
That's not so bad, was the gas in the truck 5 months old? How old is the Cat?
Re: On the Road Again...YES!!! [Re: LRJ4x4] #665054 11/10/05 09:38 PM
grass13 Offline
from what i understand, it sat with a full tank... waiting to be fixed. i bet it would have passed if they tested it under load <img src="/forums/images/graemlins/ignore.gif" alt="" />.
Re: On the Road Again...YES!!! [Re: grass13] #665055 11/10/05 10:20 PM
RSMonty Offline OP
yep, the gas is over 5 months old and I have almost a full tank. <img src="/forums/images/graemlins/frown.gif" alt="" /> By the "cat" you mean the catalytic converter? I'm still a <img src="/forums/images/graemlins/baby.gif" alt="" /> I need to check my files, but it may be original. I've had the truck 14 years and there haven't been that many parts replaced surprisingly. I guess I'm headed that way though. <img src="/forums/images/graemlins/scared.gif" alt="" /> The most recent change before the ecu was fried was the oxygen sensor.... hmmm.
My plan was to run the gas out of it, refill with high test and techron as suggested to me earlier.
Re: On the Road Again...YES!!! [Re: RSMonty] #665056 11/11/05 03:11 AM
I'd run it hard and get it good and hot before the test, too...
Re: On the Road Again...YES!!! [Re: fasteddy] #665057 11/11/05 02:15 PM
RSMonty Offline OP
The inspection station is about 10 minutes away, then I sat in line about 10. Do you think I should warm it up more than that next time?
I had trouble sleeping last night worrying about the damn emissions. And a suspicious thing happened at the station. When I got in my truck to pull away I realized that my gauges weren't working. (They were fine just moments before)
I thought maybe a fuse blew or something, so I pulled over in the station lot and got out. The inspector came over and I told him there was a problem with my gauges which had been fine. He proceeds to tell me that my truck is a "dinosaur" and "I'm lucky it runs at all." He also said I got off "easy" because "all I got was a tailpipe check and it's much tougher on newer cars." Sheesh.<img src="/forums/images/graemlins/evil.gif" alt="" /> He then tells me to "bang on the dashboard" and sure enough the gauges started working again. What do you think was up with that?
Thank You to all the Veterans out there. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: On the Road Again...YES!!! [Re: RSMonty] #665058 11/11/05 03:57 PM
DougH Offline
Mitsubishi Forum Moderator
Sounds like the inspector had a bug up his butt lol. <img src="/forums/images/graemlins/lol.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6435 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-06-10 07:22:55 UTC
