32/36 Weber passed AZ emissions!!! #665092 11/10/05 10:45 PM
ArbitraryNotion Offline OP
My dad called today to tell me it passed!! It actually had 30% lower HC and NOX than 2 years ago! I'll get a scan of the papers when I'm down in phx next time if you don't belive me.
2003
odo 157K
Test Standard
HC 1.29 3
CO 6.57 25
NOX 2.9 4.5
05
odo 176K
HCO .88
CO 7.36
NOX 1.83
If you don't remember, this is an 86 2wd with 33's and 4.30 gears (which makes the speedo right on) The exh is stock. The engine is original except I put EB's Crawler cam in it. EGR and A/S system are hooked up to the weber and with those numbers, working well.
He said that he got in the line with a little girl running it because he figured that she wouldn't notice the weber. Well he was wrong. He was watching from the waiting area as ever single guy in the place looked under the hood at the vac lines I redid. One even wagged his finger at him. They did the test and with those numbers they just told him to have a nice day! smile
I'll try to draw out a guide to hooking up emissions for a weber next time I'm in Phoenix.
Josh
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: 32/36 Weber passed AZ emissions!!! [Re: ArbitraryNotion] #665093 11/11/05 02:01 AM
84toyota Offline
I've found that many smog shops in California will refuse to even run the numbers when they see my Weber 32/36, even though there is a sticker which exempts my model from the "no no list". The shops tell me that they get in so much trouble if they do something wrong, that they won't even chance it. I end up having to find a place in "da hood" to do it for me... even then I think they just pass it through sometimes...
Ken
1984 Toyota 4x4 Truck, 4.88's, 32x11.50's, weber 32/36, aux gas tank, Warn 9500i, SR5 guages, tilt/altimeter, Alpine stereo with dual 12's behind the seats.
Re: 32/36 Weber passed AZ emissions!!! [Re: ArbitraryNotion] #665094 11/11/05 07:50 AM
4WD22R Offline
ArbitraryNotion how much of your other emissions equipment do you still have? smog pump, air injection? I'm in Phoenix and I have none of this stuff and am hoping that I'll be able to pass.....
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: 32/36 Weber passed AZ emissions!!! [Re: 4WD22R] #665095 11/11/05 04:21 PM
If it has been removed you will not pass visual. The main ones they look for are the Air Suction(Air Injection depending on the year) and the EGR. The charcol canisters must be intact also.
Re: 32/36 Weber passed AZ emissions!!! [Re: ArbitraryNotion] #665096 11/11/05 05:29 PM
engnbldr Offline
>>>*Thanks, Josh! That is good to know, we have a few folks out there that worry about passing the visual, even though the Crawler camshaft should easily pass in all 50 unless something else is haywire.
They haven't been too bad on specs here in Oregon (yet) but our Governor seems to think we should copy California which is tough on Mods.
The silly part is just like your experience, you actually improved on what the factory supplied.
I think the results tell the story, and government should take that into account....*EB
*Beats the he** outa me!....*LOL**...
Re: 32/36 Weber passed AZ emissions!!! [Re: engnbldr] #665097 11/12/05 08:32 AM
4WD22R Offline
dang guess I better start lookin for those parts....they ain't too easy to find though
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
--George W. Bush
Re: 32/36 Weber passed AZ emissions!!! [Re: engnbldr] #665098 11/12/05 04:55 PM
I'm still stoked that I improved on the factory design. Another win for webers! smile
Josh
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6221 MB (Peak: 0.7130 MB) Data Comp: Off Server Time: 2026-05-29 22:26:22 UTC
