control arm bolt #665443 11/11/05 08:53 PM
Scerb Offline OP
Doing an ifs susp lift.. I'm on the last cam bolt. I got the nut off, but the bolt is stuck to the bushing - bushing is twisting with it. I've wailed on it with a sledge, hacked at bushing with knfie.. it won't come out. I tried using some MAPP gas to burn it, but I need a new tip so that didn't work too well. Any ideas??
Also, my driveaxle has seemed to pop out of the cv inside the outer boot, is this normal or did something break?
Thanks,
Scerb
Re: control arm bolt [Re: Scerb] #665444 11/11/05 09:17 PM
willzrunna96 Offline
same happened with my... had to cut mine out and you may as well get new control arm bushings.
Re: control arm bolt [Re: willzrunna96] #665445 11/11/05 09:21 PM
Scerb Offline OP
what was your tool of choice to cut it out.. can't get grinder in there and sawzall cant really get at it either.. Oh, and napa says 15 bucks each for the bushings.. i assume i need two for one bolt? Advanced auto said 48 bucks each.. what the heck..?
Thanks,
Scerb
Re: control arm bolt [Re: Scerb] #665446 11/12/05 01:16 AM
brentox Offline
I have used a sawzall to cut the bolt out. get a short blade, one of the "torch" ones, and cut through the rubber bushining right to the bolt. its a little dicey because you have to keep the end of the blade from hitting the frame on far end of the stroke but it can be done. also get plenty of blades because you will use them up pretty quick. when you get the "A" arm off place a small bottle jack inside the "A" arm and place pressure from the inside out while heating with a torch. it stinks and is a real PITA but it has worked for me. when you reassemble break out the antiseize. i put it on the bolts and a light film on the metal part of the bushings. <img src="/forums/images/graemlins/kewl.gif" alt="" />
92 Extended Cab 4x4, 3.0 5-Speed Scratched, Dented and Rusted.
Re: control arm bolt [Re: brentox] #665447 11/12/05 03:34 AM
used a sawzal with diamond blades. they were 18 for 3 vlades and i went thru 2 blades it was a pain but it came out
Re: control arm bolt [Re: willzrunna96] #665448 11/12/05 01:17 PM
CraShYota Offline
bummer ur not here scerb me n my boss got over 500 sawzall blades from the dewalt rep while he was cleaning out his truck.
Welding and Fabrication Engineer
2003 taco V6 ext cab sr5
1988 Toyota Pickup V6(totaled)
Re: control arm bolt [Re: Scerb] #665449 11/12/05 07:33 PM
Marc91runner Offline
I used a hydraulic bottle jack (a long one) mounted horizontially and braced against the transmission crossmember to "press" out one of my lower control arm bolts.
'91 4Runner SR5 V6 4X4 Auto, A/C (self installed)
4.56, 31x10.5x15 Nokian Vatiiva's
Re: control arm bolt [Re: brentox] #665450 11/13/05 08:45 AM
A
allochris Offline
where exactly do u stick to blade to? For example, I have to cut my front left bolt. Do you stick the blade btwn the metal end of the bushing & the frame bracket? or btwn the metal of the bushing & the rubber? It's kind of thigh in there...
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: control arm bolt [Re: allochris] #665451 11/13/05 03:30 PM
brentox Offline
I just cut right into the rubber of the bushing on which ever side is most accessible. its just a little wider than the width of the blade. come in from the top, you have to man handle the sawzall because you cant let the foot on the saw rest on anything, but once you get through that bushing its smooth sailing. If your still not sure i can email a picture tomorrow, dig camera is home but all cables are at the office...
Re: control arm bolt [Re: Scerb] #665452 11/13/05 06:24 PM
Adam F Offline
I helped a buddy do it, and he ended up getting it out with a air impact hammer. You know, something like this
97 4R, stock, daily driver
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6382 MB (Peak: 0.7614 MB) Data Comp: Off Server Time: 2026-06-15 10:34:06 UTC
