Re: Rough Idle/misfire problem please help [Re: willzrunna96] #665752 11/18/05 07:08 AM
V
Van91DSM Offline
Spark plugs, dist. cap and rotor.
'88 X-Cab 4x4
'00 4Runner
'91 Talon TSi
slacker Mitsu tech
Re: Rough Idle/misfire problem please help [Re: Van91DSM] #665753 11/18/05 07:15 AM
4WD22R Offline
Ah! Don't forget the coil my fellow Glendaleian(however you spell that) <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: Rough Idle/misfire problem please help [Re: 4WD22R] #665754 11/19/05 03:36 AM
willzrunna96 Offline OP
the plugs are new and the cap and rotor are about 10,000 miles ago but show no wear. coil...yea thats 185,000 miles old. good possibility. ive noticed it only misses when the the engine warms up. but now thats its cold outside the thing runs like a raped ape. ill check out the coil with an ohm meter tommorow thanks for the idea
Re: Rough Idle/misfire problem please help [Re: willzrunna96] #665755 11/19/05 04:25 AM
Vonka Offline
My 2WD 22re was acting up big time.It was running rough and really crappy on the acceleration.I took a wild guess by changing the stock spark plug wires for some Magnecore wires that I bought over Ebay.Instant fix the truck is running great from idle to mid and high throttle.Maybe its your time to change your wires.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: Rough Idle/misfire problem please help [Re: Vonka] #665756 11/19/05 05:03 AM
just replaced the wires 2 days ago...no luck
Re: Rough Idle/misfire problem please help [Re: willzrunna96] #665757 11/19/05 06:23 AM
kewlynx Offline
Have any of you dug into your fuel injector splices yet? After all, you DID just have that engine out, so you're messing with the harnessing....
**ubi apis- ibi salus**
Re: Rough Idle/misfire problem please help [Re: willzrunna96] #665758 11/19/05 06:24 AM
V
Van91DSM Offline
Check all of the ohms on the injectors too. Maybe run some good quality fuel injector cleaner thru the tank as well.
'88 X-Cab 4x4
'00 4Runner
'91 Talon TSi
slacker Mitsu tech
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6254 MB (Peak: 0.7156 MB) Data Comp: Off Server Time: 2026-06-07 04:50:47 UTC
