Page 3 of 3 1 2 3
Re: 88 Dodge Raider Engine Swap choices [Re: MontyMcV] #665882 07/15/14 01:54 AM
I wish I'd known sooner. I was on 25E at Thorn Hill back in the spring, pulling a boat back to GA. I'd liked to have seen the fit.
Re: 88 Dodge Raider Engine Swap choices [Re: fasteddy] #665883 07/15/14 06:22 PM
ronmann Offline
Thanks for your returning my post. I started out wanting to put the diesel in my 2012 jeep wrangler but got cold feet and bough the Rader instead. I have a mechanic doing the work for me. I should have the radiator installed and be able to drive it some before I finish the project. It actually fits pretty good under the hood. I will do a 2 inch body lift and will have to modify the hood a little to make it fit properly. Putting a diesel engine in a jeep is on my bucket list. I'm in the real estate business and use my jeep to show large tracks of land. I use my jeep in 4 wheel drive a lot but I'm not a rock crawler by any means.
Re: 88 Dodge Raider Engine Swap choices [Re: ronmann] #665884 07/16/14 02:44 AM
Pics???
Re: 88 Dodge Raider Engine Swap choices [Re: Mudraider] #665885 07/17/14 05:06 PM
ronmann Offline
Here is a couple of pictures of my build.
Re: 88 Dodge Raider Engine Swap choices [Re: ronmann] #665886 07/17/14 05:12 PM
ronmann Offline
I'm having a little trouble adding the pictures, but I should be able to figure it out
Re: 88 Dodge Raider Engine Swap choices [Re: ronmann] #665887 07/20/14 11:48 PM
PartyTruck Offline
Is it a OM617 or a OM602, the turbo looks bigger than on the later model 602.
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: 88 Dodge Raider Engine Swap choices [Re: PartyTruck] #665888 07/21/14 01:00 PM
Kevin C Offline
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 17 (0.005s) Memory: 0.6242 MB (Peak: 0.7299 MB) Data Comp: Off Server Time: 2026-10-22 00:09:46 UTC
