tune up time #666425 11/14/05 08:12 PM
maxxis85 Offline OP
Well its time for me to get another tune up. I was wandering wht is the best products to use fot the toyota besides toyota parts. Any suggestions would help. Im changing plugs, wires, distributor cap, rotor, and fuel filter.
1989 TOYOTA PICKUP 4"trailmaster, 3" Body Lift 8,000 lb warn winch, q-78 tsl super swampers
Re: tune up time [Re: maxxis85] #666426 11/14/05 09:34 PM
nuclear3579 Offline
Stick to OEM wires. You'll be glad later on.
Too close for missiles, I'm switching to guns...
'97 4Runner...SR5, 4cyl (3RZ), 5spd, 4wd, no rust, excellent shape.
Re: tune up time [Re: nuclear3579] #666427 11/15/05 01:46 AM
4WD22R Offline
I've always heard, from many 'yota guys around me that NipponDenso or NGK if you're a little cheap are the best thing to get for your toy.
-1986 TOYOTA
22R
ZUK coil rear
Torqued T-Bars
Marlin HD clutch
AZTTORA #492
TLCA member
"I hear there's rumors on the Internets that we're going to have a draft."
--George W. Bush
Re: tune up time [Re: 4WD22R] #666428 11/15/05 03:28 AM
TNToy Offline
The only option for plug wires is the toyota dealer. Your truck will punish you for anything else. I've always picked up the cap & rotor from them too, but the plug wire are MANDATORY.
They may seem expensive (I think wires, cap & rotor were $50ish all together way back when) but remember that you'll be running them for about 5-6 years, as opposed to maybe a month on AutoZone wires, and a year on the cap & rotor.
For the plugs, Nippondenso (factory) should be available at autozone. NGK also work well. Those are your only two options for plugs that last. If a Toyota comes into your posession with ACDelco, Champion, etc plugs, throw as far as possible and replace with decent replacements. NGKs & Denso's are cheap enough at less than $2/plug that there's no excuse not to run them.
Feel free to replace either of these with whatever you like. I did. Twice. Them I gave up and put quality parts on there. Purred like a kitten, and still does, 5 years later. I still haven't changed anything except the plugs since then.
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.6009 MB (Peak: 0.6561 MB) Data Comp: Off Server Time: 2026-05-30 01:17:17 UTC
