tires #667868 11/19/05 05:09 AM
flyboy367 Offline OP
i need new tires. i want pro comp 30's but the wife is giving me hell to get regular tires. so whats close to those tires. i really dont want to spend more then $100 a tire. im more of a corner taking guy and working on high speed. i might not even install my lift kit if i get the right tires that make it fun to drive.
1995 nissan maxima se, 5spd short throw, aluminum flywheel and crank pully, stage 3 clutch, custom ported top end, full 2.5 exhaust jdm front end
Re: tires [Re: flyboy367] #667869 11/19/05 03:40 PM
tlab Offline
If your a corner taking guy and working on speed then I would suggest that you dont go with 30's. Also, installing the lift kit would make corners a bit hairy at higher speeds. although, when I got my new wheels with a better backspacing, it gave my sporty a wider stance and It also became alot more stable when cornering.
That being said, I do have a tire that I heard was pretty good but I cannot remember what it is called. If I remember what the name is I will post it here.
2001 dodge dakota bone stock right now.
check out the last love of my life on .....
http://members.cardomain.com/tlab1
Re: tires [Re: tlab] #667870 11/21/05 02:52 PM
Dave Scott Offline
30's would be fine, just get one that uses a 17-20" rim and are about 10-12" wide. then you can corner like nobody else, but just don't hit a pothile and don't dare take it in the dirt. <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: tires [Re: Dave Scott] #667871 11/22/05 04:41 AM
tlab Offline
I heard the Toyo Open Country are alright. They are more of a road tire than an off road tire but from looking at the tread it looks like they would be alright for light off road stuff. Not sure what the price is though.
Re: tires [Re: tlab] #667872 11/22/05 06:04 PM
MorganEstill Offline
Toyo Open Countrys are SO FREAKIN' EXPENSIVE!!! If you're looking for 30"s under $100/tire look at Dunlop, they're decent. Stay away from the Toyos if price is a slightest concern.
'97 Sportage, 4" Lift 1" BL, 31" BAJA CLAWS, Rallye 4000s, Line-Xed Hood, Grille, K&N, 2.25" Exhaust, RS9000s, GPS...
"What is IFS and where can I get some??" (outerlimits4x4.com)
Re: tires [Re: MorganEstill] #667873 11/22/05 06:36 PM
Nukeiridium Offline
If price is a big concern and you want offroad tires that look tough, consider Hi-Tec Retreads... I know you're thinking "retreads? bah!" but they have lasted really well for me, and they are a bargain.
http://www.high-tec-retreading.com/sizes.html
I opted for the green diamond tires...kinda cool... I have done some little tests of my own with wet pavement and it's really hard for me to get these tires to spin! With my old tires (also from this website but without green diamond) it wasn't hard on wet pavement to spin them.
Also, if you care much about the environment, this might interest you: It takes 22 gallons of oil to make a new tire but only 7 gallons to retread an old casing. Imagine the petroleum savings if everyone used retreaded tires... I know that's not gonna happen but it's something to think about. And most new tires, once the tread wears out, can be retreaded at least 2 times.
2002 Sportage 4dr 4x4 soon to undergo an Extreme Makeover!
Re: tires [Re: Nukeiridium] #667874 11/23/05 05:05 PM
wd8cdh Offline
I too am running the Green Diamond retreads. I am using the 30-9.50R-15 A/T size but you could also use 235-75-15.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6196 MB (Peak: 0.7108 MB) Data Comp: Off Server Time: 2026-06-07 07:05:48 UTC
