Four Wheel Drive question #668228 11/19/05 01:10 PM
Good Morning,
When the four wheel drive is engaged on my pickup and while slowing down/coasting under 5 mph, something seems to be binding. The truck will stop without using the brakes.Does this sound normal? The truck runs perfectly in 2 wheel drive.I have had this truck for a few years and have never noticed this before.
Any suggestions would be helpful
Thank you
Re: Four Wheel Drive question #668229 11/19/05 02:15 PM
strawmyers Offline
Isuzu Moderator
Are you on-road or off-road while doing this? Going straight or turning? The 4WD systyems on our trucks does not have a center differential to allow the front and rear driveshafts to turn at different speeds... and therefore should not be used on high-traction surfaces such as pavement. Even if you are on a lower-traction surface, you can experience some binding with the wheels turned if you are not giving it gas.
Sean Strawmyer
Re: Four Wheel Drive question [Re: strawmyers] #668230 11/19/05 06:50 PM
onebadtrooper Offline
Is it in low range??? If so its probably comprestion braking
Re: Four Wheel Drive question [Re: onebadtrooper] #668231 11/20/05 04:58 AM
Also (in line with strawmyers post -- if your front and rear tires are not matched for rolling circumference (different sized, air-pressure, wear) the non-differentiated t-case can also show some bind ...
Re: Four Wheel Drive question #668232 11/23/05 10:35 PM
90amigo Offline
Did you pull both drive shafts and check the u-joints?
Mine where bad and did that.Grease them when you have them out,unless your grease gun fits in with them bolted on.
<img src="/forums/images/graemlins/smile.gif" alt="" />
90 Amigo,Front 10 bolt with powertrax locker,Rear Dana 44 with Detroit Locker at 5:38.1 R&Ps,Pro Comp MT's 33x12.5 on 15x8 black Rockcrawlers,with a 3" suspension lift.Pro Comp steering Stabilizer.Warn M8000 winch in a ARB bullbar.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6038 MB (Peak: 0.6632 MB) Data Comp: Off Server Time: 2026-06-07 00:52:23 UTC
